Help, in the middle of coil swap!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abqnurse80, Sep 6, 2018.
  1. Sep 6, 2018 at 9:17 AM
    abqnurse80
    abqnurse80 [OP] Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Pulling off my fox 2.5 dsc to send to accutune. Picked up a front set from a guy with a 2013 tacoma sr5, 2nd gen to 2nd gen, should swap right in, but the stock ones I bought do not line up!!! What did these come from, are there differences from sr5 to off-road??? Any sugestions???
  2. Sep 6, 2018 at 9:19 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Rotate them
    Alexely999, blu92in99 and Mitch76 like this.
  3. Sep 6, 2018 at 9:20 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Did you try to rotate? (sorry if its a stupid question. Just asking obvious questions first)
    snowtank likes this.
  4. Sep 6, 2018 at 9:52 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah, tried rotating, they should all be the same, they are all short, about 3 1/8th on center on the stock set, my foxes are about 3 1/2 on center... Guy I got them from said they were from a 2013 sr5......
  5. Sep 6, 2018 at 9:53 AM
    Mitch76
    Mitch
    San Angelo, TX
    Can you post a pic of the whole coilover?
  6. Sep 6, 2018 at 9:57 AM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    From a 5 lugger?
    landphil likes this.
  7. Sep 6, 2018 at 9:58 AM
    Mitch76
    Mitch
    San Angelo, TX
    That was my other thought. Thats why i asked for a full shot of the CO. We can prob tell more from a pic.
  8. Sep 6, 2018 at 10:30 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    From a 2013 6 lug 4x4 sr5, according to the guy I got them from...
  9. Sep 6, 2018 at 10:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well THAT'S weird. They should bolt right up I'd think. Also 2013 or 2016? You said both.
  10. Sep 6, 2018 at 10:33 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Meant 2013,,, 16 was mistake... Weirdest thing.....
    EatSleepTacos[QUOTED] likes this.
  11. Sep 6, 2018 at 10:34 AM
    Mitch76
    Mitch
    San Angelo, TX
    I did find a pic on here of the two side by side and the diff is obvious. Dont think you have 5 lugs.
  12. Sep 6, 2018 at 10:35 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Can you take a pic of your top hat measurement, center to center of bolt???
  13. Sep 6, 2018 at 10:35 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Those top plates/top hats look different than the ones ive seen on oem shocks
    abqnurse80[OP] likes this.
  14. Sep 6, 2018 at 10:36 AM
    Mitch76
    Mitch
    San Angelo, TX
    I just found that pic in the suspension threads. Its not mine. You might check over there.
  15. Sep 6, 2018 at 10:38 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Thanks.... Will try to post over there, regardless, they arent going to work...
  16. Sep 6, 2018 at 10:41 AM
    Mitch76
    Mitch
    San Angelo, TX
    Thats strange man. Sorry about the bad luck. Hopefully you can get it resolved.
  17. Sep 6, 2018 at 10:41 AM
    BassAckwards
    Do you know if the previous owner had a spacer lift on his truck? The only thing i can think of is that maybe they swapped out the top hats for one that was compatible with a spacer of some sort.. cant say ive ever seen this though, it seems like all the spacers just bolt right on top of the top plate itself
  18. Sep 6, 2018 at 10:57 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Nah, he had it stock, replaced with Bilstein 4600.. all I can think is that these arnt the right shocks he took off....
    BassAckwards[QUOTED] likes this.
  19. Sep 6, 2018 at 11:18 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Get your money back
  20. Sep 6, 2018 at 11:23 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI, those are first gen struts (at least the top hats). Top hats are flat and stud pattern is different (smaller) as you found out.
