help installing CB radio
Discussion in '1st Gen. Tacomas (1995-2004)' started by blackhawk63, Jul 21, 2009.
  1. Jul 21, 2009 at 6:04 PM
    blackhawk63
    blackhawk63 [OP] Well-Known Member
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    3" lift, Flowmaster 40, K&N, Limo tint, HID, Grill, Billy 5100s, and more..
    hey i got an 02 tacoma and i want to install my small cb radio
    i just got it today and i do not know how to install this thing
    I saw somewhere that you can connect it to your battery but the wires are too short!
    some help would be nice
    thanks i want to get this done tonight
  2. Jul 21, 2009 at 6:07 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    what all came with the kit? did you get 18 feet of coax cable?
  3. Jul 21, 2009 at 6:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    gonna have to lengthen the wires and run to the battery with a fusible link, and i'd ground at the battery too. here is a pic of where i installed mine.....
  4. Jul 21, 2009 at 6:09 PM
    blackhawk63
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    it came with a black and red wire
    no coax cable
  5. Jul 21, 2009 at 6:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you need the long coax for your antenna........
  6. Jul 21, 2009 at 6:11 PM
    blackhawk63
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    aw man
    im not good at working with wires on cars
    this is gonna be tough
  7. Jul 21, 2009 at 6:13 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    It's just two wires and a cable...you'll be fine! :thumbsup:
  8. Jul 21, 2009 at 6:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    simple dude.....red wire goes to tbe positive on the battery...with a fuse link, and the black
  9. Jul 21, 2009 at 6:15 PM
    blackhawk63
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    yeah but how do i get it all the way to the battery and how to i connect with wires and where i get fuse link
  10. Jul 21, 2009 at 6:15 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    but yeah, your gonna need to pick up some coax cable for your cb antenna. do you have an antenna?
  11. Jul 21, 2009 at 6:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    gotta run thru a grommet on the fire wall...and autozone has fuselinks(as well as walmart).
  12. Jul 21, 2009 at 6:16 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Local autoparts store. They've got looms of wire and in-line fuses. They can help you get the right gauge wire too.
  13. Jul 21, 2009 at 6:17 PM
    blackhawk63
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    i dont have an antenna yet but there is a warning on the radio. it says
    This power cord is for 12 volts DC
  14. Jul 21, 2009 at 6:19 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Yep. That's what the car battery will give you.
  15. Jul 21, 2009 at 6:20 PM
    blackhawk63
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    ok so ill just need to go to a store to get a longer wire and a fuse line?
    that sounds easy now but where do i connect the black wire?
  16. Jul 21, 2009 at 6:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you need 2 long wires...a red and a black....black goes back to the negative on the battery. see my previous post.
  17. Jul 21, 2009 at 6:23 PM
    blackhawk63
    Ali
    Phoenix, AZ
    02 PreRunner SR5
    ok thanks! im going to autozone right now. ill post pics if i get it done tonight!
    thanks again for the help
  18. Jul 21, 2009 at 6:25 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    dude, you wil need an antenna for this thing to even work. or else you run the risk of blowing up your cb
  19. Jul 21, 2009 at 6:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....better head to a truck stop and pick up even a cheapy antenna.
  20. Jul 21, 2009 at 6:29 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    I've even seen a cheapo magnetic antenna at Wal-Mart for $10.
