Help installing coil overs!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CrsOne22, Apr 16, 2013.
  1. Apr 16, 2013 at 12:27 AM
    CrsOne22
    CrsOne22 [OP] Well-Known Member
    05 Tacoma 4x4
    K&N intake,magnaflow exhaust,5 piece billet grill, sway away 2.0 coilovers, blacked out emblems.
    i just bought a pair of used Sway away Racerunner 2.0 Coilover Shock. Any suggestions on how to install them at home? Do you have to get an alignment after installing them? thanx
  2. Apr 16, 2013 at 12:33 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    If you have a 4x4 then either undo the 2 bolts for the lower ball joint or undo the upper ball joint, the shocks should easily slide in and out then.
    If you measure and end up at the same exact height as before the lift (and you were satisfied with how it drove) then no you do not need an alignment. But if you end up at a different height then yes an alignment is needed.
  3. Apr 16, 2013 at 1:01 AM
    CrsOne22
    05 Tacoma 4x4
    I have a 4x4. I want to run the coil overs at 2.5 or 3 inches.
