Quick Links: O2 sensor issue Seeking part number for gen1 turn signal harness Just bought a '97 3RZ 4wd with 240k for cheap, need help with major replacement parts ATF Full Flush OR Drain N' Fill (w/ Brown Fluid & Slipping Trans.) Taco lean on 2wd How much longer should I wait before replacing the frame
help installing driver side filler bar
Discussion in '1st Gen. Tacomas (1995-2004)' started by brytacoma, Sep 6, 2011.
