Help! Intermittent starting problem (1st gen)
Discussion in '1st Gen. Tacomas (1995-2004)' started by woodygg, Nov 12, 2017.
  1. Nov 12, 2017 at 4:10 PM
    woodygg
    woodygg [OP] Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Hoping to figure out what's going on...
    A month or so ago my truck wouldn't start - heard the starter clicking, but wouldn't turn over at all. Attached my jumper battery to it, started right up. Didn't run it long (maybe 3 minutes) before turning it off. No more problems starting after that... until today.
    I did the same thing - strong click, that's it. Tried jumping it, didn't help - even left it on there for a long time... took the jumper batter off. When trying to start it with the dome light on, it barely dimmed - battery showed 12.4 volts - battery sounds okay (not to mention it's not very old). Alternator is almost new (not that it couldn't be defective). Pushed my truck and put in gear trying anything - thinking maybe the starter is jammed and moving it might help. Nothing. Finally it started for whatever reason.
    Obviously something is wrong, and I like to drive out to the boonies and don't want to worry... any thoughts? Starter? Starter solenoid? (those are my guesses but unsure so thinking someone can help with some insight).
    Thanks everyone!
  2. Nov 12, 2017 at 4:13 PM
    UncleShrek
    UncleShrek Well-Known Member
    Houston, Texas
    2016 SR5 V6 Auto
    TRD Pro mats, LED low beam bulbs OEM side steps, LED interior bulbs, Meso chrome delete, American tonneau cover, Replica TRD grill w/red letters, debadged, 30% Tint on door windows, 70% on windshield
    I have the same issue. Not sure what it is but my guess is that whatever it is it's stupid.
  3. Nov 12, 2017 at 4:20 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Well you live in Houston so it might be that your Taco swam a few laps recently.... :( :)
    UncleShrek[QUOTED] likes this.
  4. Nov 12, 2017 at 4:21 PM
    Glamisman
    Glamisman Well-Known Member
    tap the starter with a hammer lightly and try to start her... if it does the contacts on the solenoid are not making good contact... many threads on here about rebuilding/replacing it.
  5. Nov 12, 2017 at 4:22 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Check your ground connections
    UncleShrek likes this.
  6. Nov 12, 2017 at 4:22 PM
    Bobothehobo
    Bobothehobo Well-Known Member
    1999 SR5 3.4l
    Had the same problem, changed battery terminals. No problems since
  7. Nov 12, 2017 at 4:27 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    Thanks... I'll check all those - they were all recently replaced with an upgrade group buy from here... maybe something has come loose.
  8. Nov 12, 2017 at 4:41 PM
    UncleShrek
    Houston, Texas
    2016 SR5 V6 Auto
    I haven't changed mine but it might be the negative cable.
  9. Nov 12, 2017 at 4:42 PM
    cruiserkev
    cruiserkev Well-Known Member
    Kevin
    Lakewood, WA
    Same thing happened to me a few years ago. Had my starter rebuilt and cleaned with new contact brushes. No more issues and the mechanics who did it only charged $45 for the rebuild. Good luck!
