Help!! Ionic running boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silver 10, Dec 27, 2009.
  1. Dec 27, 2009 at 8:06 AM
    Silver 10
    Silver 10 [OP] Well-Known Member
    Joe
    Valparaiso, Indiana
    10 SR5 DBL Cab 4x4
    Nitto Terra Grapplers, Leer XL100 cap , Cabelas Bug shield , Tinted windows, Bed Mat, Husky Floor Liners front and rear, seat belt mod, Rear TSB, K&N Air filter
    Hello Im looking to get the black factory running boards and was set to get from toyota but now I came across these Ionic running boards on the internet that look exactly the same. It doesnt say if they need to drill or anything just that they come with all hardware and that it takes an hour or two to put on. Anyone have opinions or info on these if so let me know.
  2. Oct 14, 2010 at 9:22 AM
    Frank11613
    Frank11613 New Member
    Frank
    Pennsylvania
    long bed TRD SPORT
    Don't know much about them. but they do look good. Also said they come with specific brakets, should be easy to install. I was also interested in them.:)
  3. Oct 14, 2010 at 9:25 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I know there are threaded holes with plastic bolts as caps to keep crud out and they're located under you cab on the sheet metal of the cab by the pinch weld/rocker panel, and that's where the factory ones bolt to, so if you have a pic of the ones you're asking about we can most likely help you.
  4. Oct 14, 2010 at 10:07 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    I think this is what you talking about.
    I had them on my truck, they mount under the cab using 5 of the 6 holes that have the plugs in them.
    I know i had to cut the brackets back because the stuck out from under the running boards.
    I took them off because i didn't realy use them, but they are a nice product.
    Denis
