*HELP* Issues After K&N Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by DarkShadoz, Aug 8, 2015.
  1. Aug 8, 2015 at 10:39 AM
    DarkShadoz
    DarkShadoz [OP] Well-Known Member
    Jared
    Phoenix, Az
    2000 SR5 TRD 3.4L V6 4x4 Manual
    Preface: 2000 Toyota Tacoma 3.4L 4x4 252800 miles - Excellent condition motor and tranny verified by two separate licensed and reputable shops
    I recently (as in yesterday) installed a brand new, to spec, K&N Air Intake system. I have worked on my own cars before for minor work like this before and am very good at sticking to directions. I followed the directions to the 'T'. After final install and everything bolted down tight, the issue is underpowered acceleration. I tested this. I switched back to the original air box + filter. Truck ran just fine with no issues. Put the K&N back on, and same old sluggish, juttering at times (almost like little to no fuel) when pushing pedal near to the floor. Even if I take it easy on the throttle, it still feels underpowered. What gives, K&N?! YOU WERE SUPPOSED TO ADD MORE POWER, NOT DETRACT FROM IT!! (+10 awesome points if you get the reference)
    Anyways. I checked, re-checked, and checked again the Vac lines. All are seated properly. MAF sensor seated properly and cleaned prior to install. No engine codes (other than the gas cap code - but that has been there since before install).
    I dunno. Im going to have to get a spray bottle with water and soap and spray it on the vac lines to double check for leaks I guess.
    Any ideas?
  2. Aug 8, 2015 at 10:56 AM
    DarkShadoz
    Jared
    Phoenix, Az
    Forgot to mention. The truck idles high now. It will idle between 1k - 1300.
  3. Aug 8, 2015 at 11:01 AM
    trx125
    trx125 Well-Known Member
    You may need to reset the ECU. And let it relearn the fuel curve. I installed a K&N on my 3.4 4runner years ago. I had to reset the to get things kosher.
  4. Aug 8, 2015 at 11:04 AM
    DarkShadoz
    Jared
    Phoenix, Az
    Before the install, K&N instructs to disconnect negative on the battery, to which I did. Should this not have reset the ECU? Or is there something additional I need to do?
  5. Aug 8, 2015 at 11:08 AM
    trx125
    Nope, that is it! Unhook the battery(both leads) and drain off any residual energy by turning on the ignition after the battery is unhooked.
  6. Aug 8, 2015 at 11:10 AM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    If you remove the KN filter, does it run better? Maybe the filter is over oiled and restricting air flow. Just throwing out a thought. Never had issues on any oiled filters I used in the past.
    pudge151 likes this.
  7. Aug 8, 2015 at 11:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Give it some time..... When you reset the ECU, It needs time to 'LEARN' these new conditions.
    I've had drop-in filters in an old Tacoma. I've had K&N cold-air intake on a Dodge Ram and never had any issues.
  8. Aug 8, 2015 at 11:11 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    This ^^^
  9. Aug 8, 2015 at 11:12 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Sounds like a vac leak
  10. Aug 8, 2015 at 11:12 AM
    DarkShadoz
    Jared
    Phoenix, Az
    Yeah. When I tested it by switching back to the old airbox + filter, it ran fine with no issues.
  11. Aug 8, 2015 at 11:13 AM
    pudge151
    Sean
    Connecticut
    Try running it with k and n intake but no filter
  12. Aug 8, 2015 at 11:13 AM
    DarkShadoz
    Jared
    Phoenix, Az
    Thats what I was thinking, even though everything is seated properly.. Going to spray some water/soap onto the lines and see if any bubbles form
  13. Aug 8, 2015 at 11:16 AM
    DarkShadoz
    Jared
    Phoenix, Az
    I thought it may be this, considering after driving around for a few miles it seemed to get better, not by much though. The problem persists after having turned the truck off for the night, too.
  14. Aug 8, 2015 at 11:37 AM
    DarkShadoz
    Jared
    Phoenix, Az
    Ill give this a try. Thanks!
  15. Aug 8, 2015 at 11:41 AM
    anthony250f
    Anthony
    San Diego, CA
    Use propane to find vac leak
  16. Aug 8, 2015 at 11:44 AM
    DarkShadoz
    Jared
    Phoenix, Az
    Propane? Why propane? How would I even do that?
  17. Aug 8, 2015 at 11:48 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    If you don't know what you're doing, I wouldn't recommend trying it.
    Propane will get sucked into the vacuum leak and the rpm's will rise.
  18. Aug 8, 2015 at 11:50 AM
    DarkShadoz
    Jared
    Phoenix, Az
    I agree. It sounds promising, but I have never done that before. Water/Soap has always worked great, though!
  19. Aug 8, 2015 at 11:51 AM
    BadBrains
    AL
    Soapy water is usually for a pressure leak, vacuums won't blow bubbles.
    DarkShadoz[OP] likes this.
  20. Aug 8, 2015 at 11:57 AM
    anthony250f
    Anthony
    San Diego, CA
    What he said^^^
