HELP Jet Programmer #67030
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunt89, Mar 6, 2012.
  1. Mar 6, 2012 at 7:46 PM
    Hunt89
    Hunt89 [OP] Active Member
    Nanaimo BC
    07 TRD
    Pro Comp Lift 6" 33inch bfg all terrains
    Hey everyone i have a jet programmer in my 2007 4.0L tacoma. I bought it with it already installed in the truck. I am looking to remove it and if you unplug it the check engine light comes on and the truck runs like shit at idle. How do i go about removing it? If anyone has any experiances with these or any info let me know please!! thanks
  2. Mar 7, 2012 at 5:13 PM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    From what I've read around here those chips don't do anything. I wish I could help. Maybe if we get this thread back up to the top somebody else might know something.
    Bump.
  3. Mar 7, 2012 at 5:14 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Unplug it from where? Your OB2 Port?
  4. Mar 7, 2012 at 5:34 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Why not just leave it on
  5. Mar 7, 2012 at 5:44 PM
    TRDyota09
    TRDyota09 Well-Known Member
    Jabin
    Reedsville,WV
    09 Super White TRD DCSB
    K&N cold air intake, magnaflow dual exhaust, extang trifold, grillcraft black mesh grill, spyder black projector headlights w/LED's and halo's, trd 6 speed shift knob, aftermarket TRD badges, interior piped out in red,265/75-16 Goodyear Duratrac tires,painted wheels w/red pin stripe
    From what I understand from these, in order to remove it, you have to try to configure it back to stock settings before removal, and I'm not sure how its installed on the tacoma, but the Ford just plugs in like a scan tool to your OBD2 and you adjust the settings, download, and unplug. I could be mistaken but maybe that's what you need to do also. I hope this helps.
  6. Mar 7, 2012 at 8:42 PM
    Hunt89
    Nanaimo BC
    07 TRD
    thanks guys um yah my buddys a mechanic and has a scan tool we just havent got around to playing with it and hes a gm mechanic so he doesnt know a whole a lot about the toyotas but just hoped anyone new more. im just curious how it affects my mileage i may end up hooking it back up
  7. Mar 7, 2012 at 8:47 PM
    Hunt89
    Nanaimo BC
    07 TRD
    its doing something cause it trips the check engine light when i unplug it and the truck runs like shit at idle
  8. Mar 7, 2012 at 8:49 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Not true, you can change the tuning and program via OBD2
    That's exactly how toyota downloads their updates
  9. Mar 7, 2012 at 9:00 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Unplug it disconnect your battery, leave it over night unplugged (battery) then reconnect it in the morning and try to start it up. That should reset the computer. If that doesn't work then try the Contra code, that works on any toyota
  10. Mar 7, 2012 at 9:08 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ... I was under the impressing the reason the URD MAF, X-1, and my URD PCU are piggy back systems is to intercept the signals BEFORE they reach the ecu in order to modify them. Not because the ecu can't be re-programed.
  11. Mar 7, 2012 at 9:35 PM
    Hunt89
    Nanaimo BC
    07 TRD
    thanks guys um ill try disconnecting the battery, whats a contra code?
  12. Mar 8, 2012 at 2:24 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    If all else fails bring it to toyota and have them re-flash your ecu
  13. Mar 8, 2012 at 5:06 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Without taking it to a Toyota mechanic, this is probably your best bet.
    Contra code is a cheat code from an old video game... It won't do anything for your Tacoma :laugh:
  14. Mar 8, 2012 at 5:33 AM
    Bryan139
    NJ
    '09 Sport
    Up, Up, Down, Down, Left, Right, Left, Right, B, A, Start
  15. Mar 8, 2012 at 5:53 AM
    IndianTaco
    IndianTaco Well-Known Member
    :rofl:
  16. Mar 8, 2012 at 12:56 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    That was awesome and mean all that the same time lol.
  17. Mar 8, 2012 at 12:57 PM
    jw1983
    Alberta
    You have to do it fast, if you don't it won't work.
  18. Mar 8, 2012 at 1:00 PM
    Pugga
    Massachusetts
    F-150 Mod
    It's ok though, if it doesn't work the first time, just hit reset and try again.
  19. Mar 8, 2012 at 1:03 PM
    jw1983
    Alberta
    Oh but too bad. The OP don't have no reset.
  20. Mar 8, 2012 at 8:08 PM
    gt40
    gt40 Well-Known Member
    Georgia
    11 SR5 4X4 SB TOW PKG.
