HELP! Lagging Acceleration. Intermittent.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jkraz, Sep 14, 2021.
  1. Sep 23, 2021 at 8:56 AM
    #41
    Jkraz
    Jkraz [OP] Active Member
    2021 Silver Sky Tacoma SR5 4x4
    TRD Pro Grill with Raptor Lights
    Does every Tacoma have VVT Pre Filter baskets? I couldn't see them when I pulled my VVT's.
  2. Sep 23, 2021 at 8:57 AM
    #42
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    They need a dislike button. What’s next?
    12TRDTacoma likes this.
  3. Sep 23, 2021 at 8:58 AM
    #43
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Have you done a thorough visual inspection and wiggle test?
  4. Sep 23, 2021 at 9:00 AM
    #44
    Jkraz
    On what exactly? But maybe this is a joke. Lol. Any possibility it is an air intake clogged at the area under passenger wheel?
    The filter looks great.
  5. Sep 23, 2021 at 9:13 AM
    #45
    buckmaster243
    Buck
    Washington
    Can you pull the abs fuse on these trucks and get the abs system to shut down? My abs does some weird shit sometimes and cuts power. I wonder if yours could be messed up and not throwing a code.
  6. Sep 23, 2021 at 9:24 AM
    #46
    tirediron
    Very serious - all the symptoms point to an electrical issue. You've replaced most of the components which could cause/effect this issue, therefore, the most likely remaining cause is the wiring harness and connectors. Get a good flashlight, and start in one area and follow each harness. Look for signs of abrasion and damage to the conductors, pop apart the connectors and look for corrosion. With the engine running, bend/wiggle every bit of harness every few inches, as well as every conductor going to every sensor.
    If you find a damaged harness/connector/conductor, you've very likely found the issue. If the vehicle acts up during the wiggle test, you've localized the root cause.
    A clogged air intake would be a constant problem, not an intermittent one.
    Jkraz[QUOTED][OP] likes this.
  7. Sep 23, 2021 at 9:25 AM
    #47
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Definitely dislike what I just read. I saw someone above mentioned ABS. You may want to check your brake switch. If it is engaging prematurely or delaying in disengagement, you may get some of those issues you are mentioning as well. Have someone check your brake lights as you take off and make sure they still aren't on. If that tests out good, then check it digitally. Logging it's PID data against RPM data.
    winkel and Jkraz[QUOTED][OP] like this.
  8. Sep 23, 2021 at 9:35 AM
    #48
    Jkraz
    Thanks again for the replies still coming thru!
    I really dont think its brakes related as when Im going on highway it is def lacking power and Im not pressing the brakes at all. I will check these tho as I got nothing left. Thanks @12TRDTacoma
    @tirediron I will also go look at every electrical connection point. Issue is that at idle its perfect, I will give it a go tho and see what happens.
    toytaco112 likes this.
  9. Sep 23, 2021 at 9:42 AM
    #49
    tirediron
    That definitely makes it more challenging, and it may lead to naught, but this seems to be turning into a case of "When you've checked everything else, what is left, no matter how improbable, must be the problem!".
  10. Sep 23, 2021 at 9:43 AM
    #50
    Jkraz
    Reposting this one - I assume there are VVT prefilter baskets on this 2012. Can someone confirm so I can pull these as I didnt when replacing VVT.
  11. Sep 23, 2021 at 10:14 AM
    #51
    12TRDTacoma
    Rob
    Concordia
    Boosted
    the baskets are bolted into the head. One is located by the dipstick. It should be a 12mm bolt and the other one is behind where the alternator is.
  12. Sep 23, 2021 at 10:56 AM
    #52
    Jkraz
    One thing I can say is that when I dropped in new VVT this morning I disconnected battery. When put back together it immediately was like new and could burn the tires with a slight touch of acceleration. Aftera short 10 minute drive tho and stop at a light, I press the gas and back to issue.
    Previously, I had disconnected battery and looked at every coil pack and again after battery disconnect for 20 minutes it was perfect but this time for a few weeks.
    I have since tried to replicate the fix by disconnecting battery but doesn't work every time to fix the issue. This makes me think something computer related as well. Any thoughts?
  13. Sep 23, 2021 at 11:14 AM
    #53
    tirediron
    It could be computer related, but generally a bad ECM is a little less random. This really feels like a wiring issue; a bad ground, partial short to ground that only occurs under certain circumstances.
  14. Sep 23, 2021 at 12:28 PM
    #54
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Fuel pump relay? I swapped the relay to test something else and it was partially bad, causing the vehicle to drive erratically when accelerating
  15. Sep 24, 2021 at 4:21 PM
    #55
    toytaco112
    toytaco112 Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
    I swapped out my OCV last night they arrived early and so far so good but only out about 40 miles on her since then so we will see how this pans out fingers crossed
  16. Sep 27, 2021 at 6:08 AM
    #56
    Jkraz
    Well, now my eye is pointing at the air injection pump and secondary air valves. Funny enough, I had the truck in with Toyota in 2020 and supposedly they fixed the issue since it was a warranty extension or recall with the 2012's.
    I left it with a 3rd well known mechanic this past weekend. He couldn't find anything asides from thinking that was culprit.
    I plan to take it to the dreaded dealership tomorrow hoping they will confirm an issue and not be A holes. Considering it was a recall/warranty claim and been a year since the "fix" maybe they will be cool if indeed that part they know has issues and fails and "fixed" failed again a year later. Doubtful, but I have faith.
    Any suggestions? Thanks everyone, this has been brutal to say the least.
  17. Sep 27, 2021 at 8:30 AM
    #57
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    How you looked at the throttle pedal? Since it's DBW, I wonder if it is on the fritz.
  18. Sep 27, 2021 at 9:28 AM
    #58
    kuba83
    kuba83 Member
    Texas
    2006 Tacoma pre-runner TRD sport 2wd LB
    Icon Alloy Rebound wheels, Nitto Terra Grappler, 2 inch lift Bilstein 5100's
    Fuel pump?? I've put this link in a couple other similar threads..might be worth taking a look at. This was my issue with acceleration hesitation. look at thread number 6
    There's another thread somewhere here on tacomaworld with even more detail but i can't find it....but again was fuel pump issue.
    Jkraz[OP] likes this.
  19. Sep 27, 2021 at 9:45 AM
    #59
    Jkraz
    Fuel pressure remained perfect between 41-42 at idle and accelerating. I think its the secondary air valves.
  20. Sep 27, 2021 at 10:05 AM
    #60
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the secondary air valves were open when they shouldn't be the 02 sensors would see a bunch of fresh air and that would be reflected in the trims. If the trims are normal while the problem is happening then the valves are likely fine.
    The tech who mentioned the converters might be clogged may be on to something. You need an exhaust back pressure gauge, it threads into the 02 sensor hole. Anything over 1-2 lbs pressure is too much.
    12TRDTacoma, Jimmyh and Jkraz[OP] like this.
