HELP! Lagging Acceleration. Intermittent.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jkraz, Sep 14, 2021.
  1. Sep 27, 2021 at 10:20 AM
    #61
    Jkraz
    Jkraz [OP] Active Member
    2021 Silver Sky Tacoma SR5 4x4
    TRD Pro Grill with Raptor Lights
    Interesting and thank you for the note on this @b_r_o !
    I actually finally got a code to pop up that pointed to 2nd air valve, odd tho because afteer starting and stopping a few times it now is gone again. Enough time that I pulled code P2438 (just an hour ago). A mechanic this past weekend dropped the exhausts and said it made no difference in issue. I will attempt to check the cats but at 130K seems an unlikely culprit.
  2. Oct 17, 2021 at 3:38 PM
    #62
    Jjack124
    Jjack124 Member
    Jimmy
    Greenville, TX
    2006 PreRunner TRD DCSB
    What did you end up doing to to test the fuel pressure? I'm needing to test my fuel pressure, and I'm in the same boat. I've ordered a male fuel quick connector fitting so I can hook into the the existing female connector and connect into the Tee fitting in the Fuel Pressure Test kit. It won't be in until later in the week and the local parts stores don't have any in store.
  3. Oct 19, 2021 at 9:44 AM
    #63
    Jkraz
    I manually tested it with a mechanic who had the part. Then I took it to Toyota, they said nothing was wrong. So then I sold them the truck and bought a 2021. LOL.
    FML.
    Stoked to start a new build. But brutal.
  4. Oct 19, 2021 at 9:54 AM
    #64
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Whoa. That's crazy. Typically the air injection valves have a different method of failure and do not fail in the fashion that yours does. Lucky for you it doesn't kill power entirely all the time like it typically does to other folks with later second gens. It did for me when it was starting to fail.
    I'm glad you are starting to get to the root of it!
  5. Mar 25, 2023 at 9:19 PM
    #65
    toytaco112
    toytaco112 Sup
    Cedar Park, TX, US
    2012 Tacoma DBLCB 4x4 short bed
    King 2.5 Extended travel coilovers, JBA UCA's Deaver stage 2 leaf pack, All pro Aluminum replacement front with 9500lb smittybilt winch, cheap ebay rear replacement, 285.75x16 BFG All- terrains on Method NV wheels, Air ride bags light bars, rock lights bumber light bar And the list goes on..
    I know old thread but. Did anyone find a fix that was having issues. Tried all kinds of things including urd fuel pump, and VVT SOLENOIDS with no fix yet
  6. Jul 21, 2023 at 7:58 PM
    #66
    Inferno 13
    Inferno 13 New Member
    Josh
    2013 Tacoma 4x4 off road
    None
    I’m having the same problem!! Belt broke, replaced it and then it was dragging to start replaced the battery and left the parts store she was really strong, now back sluggish. Fuel mileage dropped to 10mpg Every now and then it sounds like a bit of a spark knock.
  7. Jul 21, 2024 at 5:57 PM
    #67
    Yoco07
    Yoco07 Well-Known Member
    My situation is a little different. I have an '07 Tacoma V6 2WD, and after lifting it 3 inches, adding aftermarket wheels, and installing bigger tires, I've noticed that the acceleration is not as good as it was before, and the MPG has gone down.
