Help! Lce header or regear after lift and tires????
Discussion in '5 Lug' started by Thefoot44, Jan 22, 2016.
  1. Jan 22, 2016 at 7:37 PM
    Thefoot44
    Thefoot44 [OP] Member
    Sw Florida
    2010 5lug AC
    Tint Plasti dip stock rims Ccfl spyder headlights Led Fog lights KNN CAI LED dome,map,plate, and reverse lights Plasti dip front grille and emblem Flowmaster 50series delta flow muffler
    So I just put the fat bobs lift on my 2010 access cab. I am loving the lift so far but need to get bigger tires to have it look right imo. I'm thinking that 31's are going to really make me want to regear or at least bring some low end torque back with the lce header. If anyone has input on regearing or the lce header that would be great!!??!! I have an auto with what I believe to be 3.42 gears now. I think...... Door code is A01A. Not too good with all this!
  2. Jan 22, 2016 at 7:47 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    The best headers on the market will not get you what you are looking for. Yes they will add a little bit back, but not close to what you will have lost from the larger tire sizes. Your best bet is regearing or putting a turbo/supercharger on the engine.
  3. Jan 22, 2016 at 7:52 PM
    Thefoot44
    Sw Florida
    2010 5lug AC
  4. Jan 22, 2016 at 7:57 PM
    WOODEX M.E.
    Corey
    Maine
    Nope, thats one area where i havent messed with. I have ridden in vehicles that have been regeared, and when done right the results are quite impressive.
  5. Jan 22, 2016 at 7:58 PM
    WOODEX M.E.
    Corey
    Maine
    The thread is prety new so im sure some people will chime in soon enough with answers. There are a bunch of guys on here that have regeared.
    Thefoot44[OP] likes this.
  6. Jan 25, 2016 at 5:07 PM
    TownvilleTim
    TownvilleTim Well-Known Member
    Tim
    Townville, SC
    07 ACLB SR5 2.7L 2015 DCSB SR5 V6 4x4
    TRD Pro Suspension, SOS sliders, SR8 Wheels, Duratracs, ARE shell
    I am running with the lift and 31" tires, and regearing was a must for me because I tow. The automatics are 3.58 so I regeared to 4.10. While I was at it, I installed a Detroit Truetrac and I absolutely love it. When you do tires, I recommend the lighter C rated tires unless you need more. I would love to install the LCE header, but I don't know how much farther I am going with this truck.
    Thefoot44[QUOTED][OP] likes this.
  7. Jan 25, 2016 at 5:12 PM
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    What's the approximate cost to regear to 4.10?
  8. Jan 25, 2016 at 5:14 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    500 in parts, maybe the same for labor
  9. Jan 25, 2016 at 5:15 PM
    smmarine
    Melbourne FL
    Reading on this forum the best mod you can do to 2.7 besides supercharger is the header. I plan to do it, I'm also about to go up from 4.10 to 4.56 gears
  10. Jan 25, 2016 at 5:19 PM
    SleazyPetey
    Pete
    2013 Regular Cab
    Gah damn.... Is the change from 3.58 to 4.10 that noticeable? Is it worth it?
  11. Jan 25, 2016 at 5:21 PM
    WOODEX M.E.
    Corey
    Maine
    Thats prety cheap compared to other options. Also with a change like that it will literally feel like your truck just gained 25% more power.
    HackD and SleazyPetey[QUOTED] like this.
  12. Jan 25, 2016 at 5:25 PM
    smmarine
    Melbourne FL
    I would get rid of the open diff too since you're in there. Throw a Truetrac in there. I had a Truetrac installed for $600. The carrier was $469 on JEGS. I just ordered new Gears and an install kit for $500
    You will notice a difference between 3.58 and 4.10, especially if you have 31s
    TownvilleTim and SleazyPetey like this.
  13. Jan 25, 2016 at 5:26 PM
    TownvilleTim
    Tim
    Townville, SC
    About $1100 for the gears, rebuild kit, and labor. Truetrac was another $460. It was well worth it for me. Even without towing the camper, it felt like you were dragging a dang anchor.
    That's a significant change in gearing, so very noticeable. It almost felt like you were starting in 2nd but it's back normal now. That's what the tire size calculator came up with too.
    SleazyPetey[QUOTED] likes this.
  14. Jan 25, 2016 at 5:28 PM
    SleazyPetey
    Pete
    2013 Regular Cab
    Thanks for everyone's response. Now I gotta add that to the "things to do" list for the ole Yoter
    TownvilleTim likes this.
  15. Jan 25, 2016 at 5:30 PM
    TownvilleTim
    Tim
    Townville, SC
    That's a lot of gear for 31s. However you will get out of the hole quick. I guess you know you will loose highway mpgs though.
  16. Jan 25, 2016 at 5:34 PM
    smmarine
    Melbourne FL
    The 2.7 auto came factory with 4.56. Mine came with small tires from the factory so I have 4.10. Gear calculator puts my rpm at 2600ish at 70mph. It's like a 300 rpm increase.
    TownvilleTim[QUOTED] likes this.
  17. Jan 25, 2016 at 5:35 PM
    smmarine
    Melbourne FL
    Trust me, the 2.7 needs the help. Coming from a 3.4 Prerunner to a 2.7 4wd is like going from a racecar to a bus
  18. Jan 25, 2016 at 5:38 PM
    TownvilleTim
    Tim
    Townville, SC
    I see now you have a gen 1. My bad. I don't know much at all about them. You've got it covered. :thumbsup:
    SleazyPetey and smmarine[QUOTED] like this.
  19. Jan 25, 2016 at 5:42 PM
    smmarine
    Melbourne FL
    The 2.7 isn't horrible, it's just the torque curve is a lot higher in the rpm range. Just to decently accelerate from a red light I have to be between 2-2500k whereas I could be 1750-2000 to get the same acceleration.
  20. Jan 25, 2016 at 6:57 PM
    Thefoot44
    Sw Florida
    2010 5lug AC
    @TownvilleTim how long have you had 4.10 gears in? Any issues at all?
