HELP! Leaf Spring Main Eye Squeaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by PMR85, Oct 3, 2023.
  1. Oct 4, 2023 at 9:07 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If it were me, I'd redo both of them. Not new bushings, but fresh correct grease and then torque them correctly with the weight of the truck on the springs.
    MalinoisDad likes this.
  2. Oct 4, 2023 at 4:41 PM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    Yeah, mine are squeaking too :mad: and have been for about 1400 miles now, since I got the vehicle about a month ago.
    Sprayed with Silicone spray and got small reduction in squeaks.
    Damn!
  3. Oct 4, 2023 at 4:56 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Using a spray is probably washing out any of the original Silicone from when the bushing were installed. If you're reading that correctly you should understand that spraying is making your situation worse.
    I didn't have the brand at the time of my original quotes, but @Kwikvette was kind enough to share it later.
    PMR85[QUOTED][OP] and Xbeaus like this.
