Help! LED Relay for DRL lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magneticwhite88, Jun 18, 2016.
  1. Jun 18, 2016 at 6:24 PM
    magneticwhite88
    magneticwhite88 [OP] Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Hey guys so I've been searching non stop and I couldn't come up with something. currently stuck sitting in my garage trying to figure out which relay is associated with DRL light and turn signals.
    I bought a relay to instal to solve the hyper flash issue/blown fuses but I can't figure out which relay is supposed to be replaced. Any help?
  2. Jun 18, 2016 at 6:54 PM
    magneticwhite88
    Brandon
    OC, CA
  3. Jun 18, 2016 at 7:27 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    You have to remove the lower dash and then a couple screws to be able to pull the fuse box down a bit. The relay is behind the fuse box.
  4. Jun 18, 2016 at 7:28 PM
    magneticwhite88
    Brandon
    OC, CA
    I have it pulled apart but Im still not sure, any references? All I have is a relay, not a relay harness
  5. Jun 18, 2016 at 7:33 PM
    moonman50
    moonman50 Well-Known Member
    richard
    San Diego
    2010 TRD Sport MGM
    PM csjumper2003 I know he should have everything you need
  6. Jun 19, 2016 at 5:17 AM
    Martyc6
    Martyc6 Member
    Martin
    2007 SR5 TRD sport, 6' bed, ext cab V6
    Volant ramair.
    I found mine, on the back of the fuse panel, what I did when I had the fuse panel unbolted I turned the blinker on and found it that way
  7. Jun 19, 2016 at 5:35 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think what you are looking for is called the T11 Turn Signal Flasher. It is not just a relay.
    The DRL is controlled by the Body ECU that sends a signal to the flasher to turn on the DRL Lights.
  8. Jun 19, 2016 at 8:57 AM
    magneticwhite88
    Brandon
    OC, CA
    Yeah the guy at Oreilly's told me I could just use a relay and it would be much easier, he ever said he did it on his car which is probably a 1980 civic. HA! they were out of the resistors. After debating for 5 minutes I took his word. Come to find out after 3 hours of searching the net I needed a relay harness/flasher relay so I went back to an Oreilly's that had resistors in stock, made the switch, and it took me all of 15 minutes to install the resistors.
    Thanks for the feedback guys
  9. Jun 19, 2016 at 9:08 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Did it work? No hyper flash
  10. Jun 19, 2016 at 9:11 AM
    magneticwhite88
    Brandon
    OC, CA
    Yes it worked, no hyper flash and more importantly the fuse for my DRL's doesn't blow from having the LED's in.
  11. Jun 19, 2016 at 9:15 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    So what exactly did you replace or did? Been trying to solve this issue for the longest
  12. Jun 19, 2016 at 9:20 AM
    magneticwhite88
    Brandon
    OC, CA
    If you go to Oreilly's, auto zone, or Amazon you can buy load equalizers (resistors) to resolve the hyper flash issue. The LED's pull less power so the vehicle thinks the bulb is out, which is why hyper flash occurs. All you have to do is install 1 resistor by tapping into the wiring harness associated with the bulb you change. I did the blinkers in my tails last night, so I used 2 resistors total.
    The resistor must be set up in a parallel circuit meaning you must splice into the power and the ground wire. Ill post pics later today, I get off work at 1.
  13. Jun 19, 2016 at 10:06 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    Ah, nvm. Yeah I know about the resistors. I thought you had replaced the flasher. I re read everything. Haha my bad. In a tundra, you can actually replace the flasher. Thanks
