Help Leveling my TRD Offroad Prerunner
Discussion in 'Suspension' started by ZachPrerunner, Jul 7, 2015.
  1. Jul 9, 2015 at 8:25 AM
    #41
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I believe the OEM coils already account for taco lean, as they're side specific. So a spacer isn't needed.
  2. Jul 9, 2015 at 9:56 AM
    #42
    ZachPrerunner
    ZachPrerunner [OP] Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Thank you everyone for your responses. It's definetely helped on making my decision. I'm going to run the shocks @ .85 on the stock coils. If the ride is too stiff for my liking, then I'm going to readjust to factory hight and potentially install some new coils. If I decide to upgrade coils, which brand should I look at. Id want the truck at the height that the bilstein 5100s provide at .85. My budget would be $250-300 on coils.
  3. Jul 9, 2015 at 9:58 AM
    #43
    T4RFTMFW
    Coils are much less than that. OME 885s for example are $169 +/-.
    You'd probably be okay with 883X around 1.5", but there might be another coil option for you to consider.
    @YotaDan ?
  4. Jul 9, 2015 at 10:03 AM
    #44
    ZachPrerunner
    Southeast TN
    What if I upgrade my progressive coils to the stock linear coils found on the TRD Sport/SR5 models. I did some more research last night and found that the Offroad model is the only Taco with progressive coils. The ride would most likely improve correct considering I don't offroad in any extreme cases?
  5. Jul 9, 2015 at 10:06 AM
    #45
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    n a 2nd Gen Double Cab you would see about 1" of lift out of the OME 883 coils. They go for $167.20
  6. Jul 9, 2015 at 10:08 AM
    #46
    ZachPrerunner
    Southeast TN
    How stiff would the ride quality be with those? I really just don't want to have to deal with taco lean to be completely honest.
  7. Jul 9, 2015 at 10:11 AM
    #47
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Marginally firmer. For the lean you would add a small spacer to the driver side.
  8. Jul 9, 2015 at 10:13 AM
    #48
    ZachPrerunner
    Southeast TN
    Okay so you would recommend the 883 over the 885? Which spacer would you suggest as well?
  9. Jul 9, 2015 at 10:18 AM
    #49
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you are only after .85" of lift, then yes. If you are running OME Shocks it would be a 95PF5 Trim Packer. If you are running Bilstein or other shocks then it would be a 1/4" Top-spacer.
  10. Jul 9, 2015 at 10:21 AM
    #50
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
  11. Jul 9, 2015 at 10:21 AM
    #51
    ZachPrerunner
    Southeast TN
    Alright, I'll give the stock coils a chance and then decide if I want to upgrade.
