Help Leveling, Rims & Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kgberry, Jul 25, 2017.
  1. Jul 25, 2017 at 10:35 AM
    kgberry
    kgberry [OP] Member
    Kat
    2015 Tacoma Access Cab
    Hi All!
    I'm looking for some help. I want to put a 2" leveling kit on my 2015 Tacoma (Access Cab, Manual Tranny). I am kinda short so I don't want to look like an idiot getting in and out of my truck.
    I'm looking for some brands and dimensions for some rims and tires that would go well with a 2" level. With tires I'd like the overall lift to end up being about 4". I'll be off roading so I prefer no low profile tires.
    Thanks!
    ChadsPride and klevbot like this.
  2. Jul 25, 2017 at 10:42 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome Kat! Tons of tires and wheels to chose from. Popular sizes for a 33" tire are 285/75R16 and 255/85R16. How tall are you?
    ChadsPride likes this.
  3. Jul 25, 2017 at 10:46 AM
    kgberry
    kgberry [OP] Member
    Kat
    Thank you! I am about 5'5". I was going to put nerf bars on for assist haha
  4. Jul 25, 2017 at 10:47 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I'd suggest against nerf bars if you plan on off-roading. Those will rob you of a few inches of clearance. At 5'5" I bet you will be able to get into the truck just fine if your legs aren't too short.
  5. Jul 25, 2017 at 10:51 AM
    kgberry
    kgberry [OP] Member
    Kat
    Awesome! Thanks for the advice. I was debating that myself.
  6. Jul 25, 2017 at 10:52 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
  7. Jul 25, 2017 at 11:12 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I'm 6ft even with a 3in lift and my ass barely cleared the seat to be able to "slide" in.
    I think you'll be fine!
    kgberry[OP] likes this.
  8. Jul 25, 2017 at 11:34 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    If it means anything, I have a 3" lift with 33's, AND N-Fab steps. I haven't damaged them yet while wheeling.
    kgberry[OP] and ChadsPride like this.
  9. Jul 25, 2017 at 3:32 PM
    klevbot
    klevbot Active Member
    kyle
    2014 BR Tacoma 4x4 baja
    dont put 33's on ur truck w a 2 inch leveling kit. thank me later :p 31's 31.5 would be about right. i know toyotech or toyotec makes a decent leveling kit. not too expensive.
  10. Jul 25, 2017 at 3:40 PM
    klevbot
    kyle
    did u have any problems with your n fab stuff mounting up ? i just got 50 inch roof brackets for a LED bar did not fit whatsoever for $199 they did a good job etching their name into it though lol they were truck specific too
  11. Jul 25, 2017 at 3:43 PM
    replica9000
    2019 T4R ORP
    They mounted perfectly. Only issue I had with N-Fab is I have the stainless version, which they apparently had for sale months before they went into production. So I had to wait an unknown amount of time after already paying for them.
  12. Jul 25, 2017 at 6:38 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @boogie3478 :oldglory: If there is anything that I can help you with just let me know @kgberry :D
  13. Jul 27, 2017 at 10:10 AM
    jrob
    jrob Member
    Joshua
    2010 Tacoma 4x4 double cab long bed
    Hey guys,
    I would love to piggy back on this thread. I am new to the forums btw :) I have a 2010 tacoma 4x4 long bed that i bought with a little bigger tires already on it. Right now it has p265/65r17 on it. I am adding a rough country 2in leveling kit today. I would love to get a little bit bigger tire if possible. Does anyone know if I can get a little bigger tire with adding the kit without making the ride a lot rougher? Thanks in advance!
  14. Jul 27, 2017 at 10:15 AM
    Chase8059
    Chase
    ESVA
    265/70r17 is a popular tire size on here.
    And if your buying "Rough" Country spacers, be prepared for a rough ride.
    boogie3478 and jrob like this.
  15. Jul 27, 2017 at 10:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    The kit will be the problem re rough riding. Not the tires.
    There are many threads on lift options and tire sizes. But one of the critical fitment factors is the wheel used. Many have specs that require some other alteration for the tires not to rub.
    Some folks are running 255x80 or 85 on OE wheels with no rubbing. That's a pretty tall tire. Gives more ground clearance, bit more sidewall cushion and fills the wheel wells nicely.
    Wider isn't always better.
  16. Jul 27, 2017 at 10:17 AM
    jrob
    jrob Member
    Joshua
    Lol fair enough. If you have other recommendations for a 2 inch leveler I am all ears.
    HeadStrong Off-Road likes this.
  17. Jul 27, 2017 at 10:19 AM
    Chase8059
    Chase
    ESVA
    Bilstein 5100s set at 1.75.
    As mentioned for the OP, give Marie at Headstrong a call. @HeadStrong Off-Road
  18. Jul 27, 2017 at 10:26 AM
    jrob
    jrob Member
    Joshua
    So don't using a leveling kit? Does it mess with the ride to much? You also recommend the 265/70r17 with the slight lift? Thanks again for your help!
    Anyone else have something to add?
  19. Jul 27, 2017 at 10:49 AM
    Chase8059
    Chase
    ESVA
    To keep it simple, Lift and Level are pretty much the same thing. If your leveling the front, your techincally lifting just the front.
    Front spacers are a cheap way to lift and provide no advantage except for looks.
    Bilstein 5100s are relatively cheap. I think you get them for under $200 just for the front. It's an adjustable shocks that let's you move the bottom coil seat. This puts the coil under more compression and raises the front of the truck. It's the most common entry level lift you can do without sticking hockey pucks on top of your coils.
    Yea, 265/70r17 is a 31.5 tire. I have a 3in lift and still run those size tires.
    kgberry[OP] and MattCowsmasher like this.
  20. Jul 27, 2017 at 11:01 AM
    jrob
    jrob Member
    Joshua
    Very helpful. Thank you!
