Help! Lift and wheels/tire question!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alabamaprerunner, Sep 30, 2012.
  1. Sep 30, 2012 at 7:33 PM
    Alabamaprerunner
    Alabamaprerunner [OP] Member
    Alabama
    08 PreRunner
    K&N
    I recently put the toytec leveling kit on my 2008 PreRunner DC. I have the 20x9 XD Armour wheels and a 305/55/20 terra grappler and I'm rubbing like crazy on the frame and fenders. Any fix for this without grinding or am I just gonna have to order a smaller tire? Spacers help? Geez I know better than to mess with my stock stance.
  2. Sep 30, 2012 at 7:36 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    Holy shit balls! You are definitely going to need to do some heavy trimming. Might even have to trim your exhaust manifold.....
  3. Sep 30, 2012 at 7:36 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Problem is you're running 33x12s on pretty much no lift (I don't know what you're leveling kit consists of)
    Either upgrade your suspension significantly or downsize your tire significantly, or probably best would be to do a combination of BOTH but it's going to cost you
  4. Sep 30, 2012 at 7:37 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Yes, and trim. . . trimming isn't even the word for that size tire haha more like cutting or hacking
  5. Sep 30, 2012 at 7:39 PM
    TeamLombardo
    Tony
    El Paso
    LOL! Chainsaw the shit out of it.
  6. Sep 30, 2012 at 7:46 PM
    Alabamaprerunner
    Alabama
    08 PreRunner
    K&N
    So what's the ideal tire size? I have 2 inch block in back and the leveling kit I front. Think it is a 2.5
  7. Sep 30, 2012 at 7:51 PM
    TeamLombardo
    Tony
    El Paso
    Well it all depends on what you are doing with your truck. How often and what type of wheelin are you doing? What are you willing to dotofit tires in there?
  8. Sep 30, 2012 at 7:51 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    At 2-2.5" of lift you can run a 32-33 depending on a few things
    Just keep in mind tire size, tread, load rating, etc. should be chosen for the application they were made for, not just what looks cool.
    The better questions are, what are your goals (ie clearance), what terrain will you be driving on mostly, are you fuel efficiency minded or is that irrelevant to you, highway a lot? city? dirt, sand, mud, snow? etc. . .
    Width is going to play a factor in fit as well as height. a 255 will fit easier than a 305
  9. Sep 30, 2012 at 8:01 PM
    Alabamaprerunner
    Alabama
    08 PreRunner
    K&N
    Mine is a street queen. Don't wanna hack it up. My truck is basically treated like a car. Lol
  10. Sep 30, 2012 at 8:05 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Then I don't know what to tell you man. I guess just get whatever size tires you want but if you never off road then I don't see you needing anything bigger than stock or at most a 32.
  11. Sep 30, 2012 at 8:07 PM
    TeamLombardo
    Tony
    El Paso
    x2
  12. Sep 30, 2012 at 8:32 PM
    Alabamaprerunner
    Alabama
    08 PreRunner
    K&N
    I just like the big and beefy stance.
  13. Sep 30, 2012 at 8:50 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Thats good as far as rubbing goes.. since offroading stuffs your tire. but only option is to cut plastic/cab mount and be rub free. Trust me its worth trimming
    Edit: Option 2 ditch the spacer lift use stock coils and get spindles, should stop the rubbing
