HELP LIFTER PROBLEM????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kyle, May 23, 2011.
  1. May 23, 2011 at 7:59 PM
    Kyle
    Kyle [OP] Mckeown343
    Arcata
    05 PreRunner
    3 inch toytec, magnaflow exhaust, KNN intake, URD MAF, HID 55 watt, Hella 500 HID, Smoked tail lights LED running lights, Pioneer deck with 8 inch infinity sub, Focal 165VB and 165CVX with JL 320/4, Tinted all around 3%, Tinted interior lights.
    Hey whats going on I have noticed a loud ticking noise coming from the engine :confused:. The sound only comes when the truck is hot and varies throughout RPM range. The truck has 62K on it. Does this sound like a lifter and why so early in the trucks life. Any info is appreciated.
  2. May 23, 2011 at 8:12 PM
    Kyle
    Arcata
    05 PreRunner
    Bump
  3. May 23, 2011 at 8:17 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    <search function>
    The Stealership says it's injector noise, and it seems that everyone with the 1GR-FE seems to have the same ticking noise. I had mine from brand new,and some people have never heard it... hit and miss a guess.
    Anyways, nothing is wrong with your engine. Just turn up the stereo and enjoy your truck!
  4. May 23, 2011 at 8:19 PM
    Kyle
    Arcata
    05 PreRunner
    Ya for sure I will try that. No one has had any lifter problems??
  5. May 23, 2011 at 8:24 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    our trucks tend to tick on a regular basis. Did you notice this only after you lifted it? Or was it going on previously?
  6. May 23, 2011 at 8:26 PM
    Kyle
    Arcata
    05 PreRunner
    It just started happening about a month ago. It has progressively gotten worse and is not a little tick like I know tacomas have its annoying and loud! lol
  7. May 23, 2011 at 8:27 PM
    Hiatt1991
    Hiatt
    you should pull a couple of your plugs and check em out. Look at the residue on them. Do you push your engine hard? When is the last time you changed your oil?
  8. May 23, 2011 at 8:30 PM
    Kyle
    Arcata
    05 PreRunner
    Sometimes I have to with the 2 wheel and being up in Northern California. So yes sometimes over rev. I change the oil every 5K and I use mobile 1 Extended performance with a KNN oil filter. I talked to a local mechanic and he was saying its a lifter because of over rev???
  9. May 23, 2011 at 9:25 PM
    Hiatt1991
    Hiatt
    It could possibly but our engines have a limiter and I havent seen anyone on tw that messed up a lifter. Try and look for a user named: Chris4x4. Hes basically the TW mechanic. Shoot him a PM.
