Help: LIGHTING ISSUE (LED's)
Discussion in 'Lighting' started by Solution.45, Nov 23, 2016.
  1. Nov 23, 2016 at 9:16 AM
    Solution.45
    Solution.45 [OP] Well-Known Member
    Chase
    Redding CA
    2011 White 4x4 double Cab
    When I bought my truck it already had the turn signal/running light LED mod in it and now things are messing up on a consistent basis. Turn signal timing, turn singnals not working at all, one running light not on.....etc. It seems like an easy fix but Im not the best with electrical. Is there someone in San Diego or Ventura CA that can look at this so i dont have to take it to an expensive electricalshop....I have OCD and this issue is bothering the f*** out of me.
  2. Nov 26, 2016 at 7:40 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Put halogens back in?
  3. Nov 29, 2016 at 6:59 AM
    rustynailz
    rustynailz Active Member
    thunder bay ontario
    08 double cab lg bd
    It's an easy fix... Is it both sides? Front, rear?The timing on your blinker just means that a bulb is burnt out.. I just had the same problem.. For the one running light I had to connect a wire from the other side to the one that wasn't working(from passenger side to my drivers side) for my blinker the wire was broken off from one of the harness, I just by passed the harness. then I had readings of 12 volts of everything but still no light so I put a wire for the ground by passing the harness.. I put the wire close to where the ground is connected to the truck and reconnected it just before it splits into 3 to go to each light... Blam they all work. Lots of problems with the tail lights in tacomas I hear, not much info online for it tho.
