Help looking at buying 05 taco 4x4 double cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by morrison336, Mar 1, 2014.
  1. Mar 1, 2014 at 5:05 PM
    morrison336
    morrison336 [OP] New Member
    Brandon
    North carolina
    Hey guys I wanted to know if anyone has had problems or what to watch for on the 05 Tacoma 4x4 double cab sr5 I'm looking at buying one it has 90,000 almost roughly 91,000 miles i haven't got the chance to look at it and I'm also going to be moving to Alaska in June so any kind of advice is greatly appreciated thanks
  2. Mar 1, 2014 at 5:09 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Rusty frame. Broken motor mounts.
  3. Mar 1, 2014 at 5:19 PM
    tclarke1
    tclarke1 Well-Known Member
    Tyler
    Arizona
    09 Prerunner SR5 Single Cab 2wd
    Tint, Subwoofer, De-badged, Billet Grille, URD Short Throw Shifter, MaxTrac Spindles
    Can you post the link for us to see it??
  4. Mar 1, 2014 at 5:30 PM
    angryseas
    angryseas Member
    mike
    new england
    check the frame defintely but from where you are i dont think it should be as much of an issue(wish i could hae you buy me one and send it up to the northeast as frame rust a much more concernign issue up here in buying used) good luck
  5. Mar 1, 2014 at 5:32 PM
    morrison336
    Brandon
    North carolina
  6. Mar 1, 2014 at 6:11 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Check for broken or cracked motor mounts. If it has LSD rearend, ask the owner if he's changed rearend oil or had any issues with it.
