Help!!! Lots corrosion on my shocks
Discussion in 'Suspension' started by wangluoqis, Mar 15, 2013.
  1. Mar 15, 2013 at 11:03 PM
    wangluoqis
    wangluoqis [OP] Active Member
    Regina Saskatchewan
    2013 Tacoma DC SR5
    Hi guys,
    I got this Fox Factory Series shocks installed in beginning of Jan and now it has lots of corrosion on them after only 3 months on my truck.
    The ring for adjusting preload on one side is completely locked could not make it move even with a spring compressor. I am assuming that corrosion is stopping it to move.Another side has corrosion too but ring is moving hardly. Is this a quality issue? I brought it brand new from ORW in Dec last year and had only ran them for over 3 months now. what should I do??
  2. Mar 16, 2013 at 1:17 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    That's after 3 months? Yikes!
    I'll keep an eye on mine and keep them clean.
  3. Mar 16, 2013 at 1:20 AM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    you got foxed :spy:
  4. Mar 16, 2013 at 6:46 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    that is normal
    depends on what conditions you drive in
    scrub that stuff down a drizzle boeshield on it from now on if it bugs you
  5. Mar 17, 2013 at 12:42 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    I've got some similar issues on the bodies of my Fabtech Dirt Logic coil overs....everytime I wash the truck I scrub them down and also use a detail spray (Pig Spit) to protect/prevent corrosion. After a year I have slight surface rust forming.
    Yours may have corroded faster due to exposure to rock salt.:confused: Without regular washing rock salt really does a number on metal. Luckily they don't really use that stuff down here in VA Beach ;)
  6. Mar 18, 2013 at 11:23 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    YIKES! Dats a lot O road salt...
  7. Mar 18, 2013 at 3:49 PM
    jmast
    jmast Is it June yet
    O.I.C.
    2011 DCLB TRD SPORT
    Taz mudflaps
    shock socks FTW!!
  8. Mar 18, 2013 at 3:58 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i'm wondering if anyone has actually bought these yet and used them
  9. Mar 18, 2013 at 3:59 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Protect it with Fluid Film
  10. Mar 18, 2013 at 6:16 PM
    jmast
    O.I.C.
    2011 DCLB TRD SPORT
    Taz mudflaps
    using this now...although the rock salt season is at its end here in NE Ohio I still want to protect my suspension upgrade
  11. Mar 18, 2013 at 6:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
