Help make my mind up.... suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nothingmajor_tacoma, Aug 21, 2017.
  1. Aug 21, 2017 at 6:12 AM
    nothingmajor_tacoma
    nothingmajor_tacoma [OP] Member
    Austin
    2010 Timberlandmica TRD Sport
    "Nothing Major"
    I was dead set on ordering OME 885s, bilsteins, AAL, and UCAs. Meanwhile Toyota is taking their sweet time getting my new leaf pack (previous owner didn't take care of recall) so I've had time to think more than I should about my choice but at the same time it's giving me time to save. Besides the kit I thought I was set on, what are some other sub or around $1500 options?
  2. Aug 21, 2017 at 6:13 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    depending on how tall you are going, you could do bilstein 6112s/5160s with dakar leafs and if you don't go too tall you won't need upper control arms so that should be around 1500
  3. Aug 21, 2017 at 6:29 AM
    nothingmajor_tacoma
    Austin
    "Nothing Major"
    Wanting to stay at or under 2.5
  4. Aug 21, 2017 at 7:09 AM
    jpereira2
    Massachusetts
    Then most people would say you wouldn't need UCA's. I got them anyway and I am at around 2.5"
  5. Aug 21, 2017 at 7:30 AM
    Pigpen
    Dan
    Northwest Montana
    My truck handles like shit at 2.5 on stock UCAs compared to how it rides now with LR UCAs. You can always add the UCAs though.
  6. Aug 21, 2017 at 8:19 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    UCAs don't only help with alignment, they also aid articulation on lifted trucks. Well worth the expense IMO.
    Hardscrabble likes this.
