HELP! Map/Overhead lights won’t turn on in DOOR pos.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WalkDown13, Nov 8, 2024.
  1. Nov 8, 2024 at 12:57 AM
    WalkDown13
    WalkDown13 [OP] New Member
    Jack
    North Carolina
    2013 SR5 4x4 V6
    Hi everyone,
    I’m new to the forum, looking for some help with my 2013 base double cab 4x4-
    I have the dome light set to “Door” position, and it comes on when I open the doors or unlock the truck, but the overhead/map lights in the front do not, is there any way to fix this?
    Appreciate the help.
  2. Nov 8, 2024 at 3:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    The map lights should not.
    Does the front light come on under any conditions?
    Have you checked the bulb?
    Any chance you've installed LED wizardry backwards?
  3. Nov 8, 2024 at 6:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The map lights don't come on with the dome light unless you mod them to.
    There's a thread on here somewhere about it, I'll have to find it.
  4. Nov 8, 2024 at 10:19 AM
    WalkDown13
    Jack
    North Carolina
    2013 SR5 4x4 V6
    Appreciate the response,
    the two overhead lights in the front come on if I push them, but not under any other circumstances. Is that what is supposed to happen?
  5. Nov 8, 2024 at 2:06 PM
    mark_tga
    mark_tga Well-Known Member
    2015 Tacoma DCSB
    That is correct. The map lights don't come on with the dome lights. This baffled me too. You can mod map the light to come on at the same time as the dome lights though. It's pretty simple. I'll see if I can find a link to it.
  6. Nov 8, 2024 at 2:08 PM
    WalkDown13
    Jack
    North Carolina
    2013 SR5 4x4 V6
    Good to know, thanks.
    If you find that link I'd love to see it, would definitely be a mod I'm interested in
  7. Nov 8, 2024 at 2:10 PM
    mark_tga
    2015 Tacoma DCSB
  8. Nov 8, 2024 at 2:36 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I did the mod on my 2014. It makes a nice/big difference in my opinion. The interior is literally dark without it, especially the front seat area. The oem bulb is only 10 watts. Dunno if there is a higher outage bayonet bulb out there that would work, but most likely it would run much hotter and I wouldn't experiment with it and have it melt (or worse) the likely big $$$ dome lamp unit.
