Help me avoid death and death related symptoms
Discussion in '1st Gen. Tacomas (1995-2004)' started by MacGyvR, Aug 25, 2011.
  1. Aug 25, 2011 at 3:56 PM
    MacGyvR
    MacGyvR [OP] Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    I need a new suspension all the way around. New coils, leafs, and shocks. As a starving college student, there's no way I can do all of this at once. Especially since I'm getting new tires in September. Where would my money be best spent? I think the most I can spend is $300ish.
    I eventually want to have this setup
    Billy 5100's
    Stock coils
    AAL, or a new leaf pack
    I was thinking I should do the front coils and shocks first, since I think doing one without the other will damage the new components. What do you think?
    Suggestions would be greatly appreciated!
  2. Aug 25, 2011 at 5:31 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    :spy:
  3. Aug 25, 2011 at 5:38 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Need or want?
  4. Aug 25, 2011 at 5:41 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    this...cause....yeah.
  5. Aug 25, 2011 at 6:07 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Sounds like you should get some gently used stuff if you can't afford to eat but you HAVE to have new suspension. Or if you buy oem style shocks with no lift you can save hundreds now and save for later...
  6. Aug 25, 2011 at 6:25 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    If your shocks are worn out, I would replace those front and especially back for safety's sake to keep your tires on the road. Those new tires won't do you any good if the aren't contacting the pavement.
    Don't bother lifting/replacing springs until you can afford to do it right.
  7. Aug 25, 2011 at 9:12 PM
    MacGyvR
    Tom
    Arizona
    Need.
    The ride quality is pretty shitty, which I don't mind much, but I get nervous when there are messed up sections of road or highway that I have to take at speed. Especially when turning!
    Is it worth getting OEM shocks? I thought they would wear out faster.
    Also, I'm not sure gently used has very much meaning. Someone can say their shocks only have 5k of highway miles on them, but how do I know they weren't out off roading? I don't have enough experience with these components to recognize that kind of wear and tear.
  8. Aug 25, 2011 at 9:16 PM
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Drive more cautiously then. If you were in Saint Louis I'd sell you my old leaf pack with a 2" aal for 50 bucks and lunch. I haven't thought of a price yet but I have rear 5100s that I need to get rid of as well.
  9. Aug 25, 2011 at 9:24 PM
    Dilley
    Dilley Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    Cant you just create some out of some paperclips and chewing gum Macgyvr?
  10. Aug 25, 2011 at 9:35 PM
    MacGyvR
    Tom
    Arizona
    Yeah, that would be nice. That's at least 15 light years from where I live though.
    Where do you think my original suspension came from?
  11. Aug 25, 2011 at 10:00 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    You are describing what I felt about my truck when I got it used. I was alarmed at speed in bumpy freeway curves at the speed of surrounding traffic. This is a safety issue. That is why I advocate shocks first. New shocks wil do a better job of controlling worn out springs, which you can't afford to replace right now.
    Shocks wear out over time. Getting another set of Bilstein HDs will get you through another 20-50,000 miles. They are good shocks. And I suggest new ones, not used. Shock length is specific to suspension ride height. When you can afford a proper lift, it means that you can afford the proper shocks to go with the springs you choose.
  12. Aug 26, 2011 at 7:59 AM
    MacGyvR
    Tom
    Arizona
    This sounds like a good solution. Do you know where I can get billy HD's for a good price? From what I've seen it looks like it would be only $100 more for 5100s all around.
  13. Aug 26, 2011 at 8:07 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Save your $100... You said you were a poor college student now you want to spend an extra $100 on 5100's when you don't need them? Make up your mind!
    Try local auto parts stores for Bilstein HD's, or go to Bilstein's website and find out who carries them local to you.
    EDIT: You might be able to get 5100's, I can't find HD's $100 cheaper than what Downsouth Motorsports lists the 5100's for.
  14. Aug 26, 2011 at 8:21 AM
    MacGyvR
    Tom
    Arizona
    lol, I am poor. But if the 5100s last substantially longer, I can see waiting a little longer to save the money. I'm just looking at all the angles.
    Edit: Autozone carries the HDs for either $65 or $89 each (couldn't figure out which one I needed), which would come to either $260 or $356 before taxes and shipping. I remember seeing that down south motorsports was selling the 5100 pack for like $309 before shipping and taxes. I'll just go with the 5100s if I can't find the HDs for substantially cheaper.
  15. Aug 26, 2011 at 8:34 AM
    Sign Guy
    Sign Guy Well-Known Member
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Nice Rims, Big Tires, Carryboy Shell, Added Rosta Cruise Control & Ultraguage, 5100 Bilsteins All around
    I got my 5100's from downsouth (great deal!). I don't remember who I got my AAL from but it was under $100 and really helped lift up that saggin rear end.
  16. Aug 26, 2011 at 9:12 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Just make sure when you get the shocks that you get the right part numbers--especially if you order online. This sounds weird, but you need three different shocks:
    2 front (same part number)
    1 rear driver side
    1 rear passenger side
    Have you tried RockAuto?
    The rear schocks are side-specific becasue they are different lengths.
  17. Aug 26, 2011 at 10:50 AM
    MacGyvR
    Tom
    Arizona
    Just took a look at rock auto, and I'm kind of blown away. I can get new shocks for as low as 18 each!:eek::eek::eek:
    How do I pick the correct shocks? I see that a few say RR and front, but none seem to say rear passenger. Also, could someone recommend or give me advice on what to pick? I don't want to pick the cheapest shocks only to have them wear out after 10k miles.
  18. Aug 26, 2011 at 10:54 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Bilstiens all the way around--you do not need the AAL yet--unless you have a HOT TUB in the bed.
    I did the aal FIRST--Because of heavy loads--Shocks were still good.
    Safest and best thing to do--get the bilstiens.
  19. Aug 26, 2011 at 11:03 AM
    MacGyvR
    Tom
    Arizona
    I'd love to get the billies, because I'd like to lift it an inch or two eventually, But if I can get new shocks all around for under $150 I can't rationalize the spending at this time... Unless they're going to last forever, lol.
  20. Oct 5, 2011 at 9:33 PM
    whatatoy
    whatatoy Galt/Rearden 2012
    SO CAL
    I like it
    This truck is a work truck - not a lot of fancy mod's here, but it's getting the job done!
    I'm reviving the thread here because I would like some help here - I'm not a starving college student, but I dont have a bunch of money to spend on the SAS I really want, so I'll have to go with just replacing my shocks instead. I have a 98 prerunner. If someone could recommend which shocks (pref with part number) I would appreciate it - especially if there are 3 different one's to order. My budget is around $2-300 at most and I will be replacing all 4 doing the work myself. Thank you.
