Help me be a hero: GF's 2005 Nissan Altima Brake Issue
Discussion in 'General Automotive' started by Madjik_Man, Nov 15, 2014.
  1. Nov 15, 2014 at 10:05 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    On cold mornings: She starts the car and slowly proceeds to drive out of her apartment parking lot. Comes to the stop sign, goes to push the brake pedal and it barely moves. Obviously brakes don't engage.
    As the car warms up, the brakes operate normally.
    Does not happen in warmer temps.
    Sounds hydraulic to me, as if the brake fluid is too viscous from the cold and not operating as it should. I have no idea what type of fluid is in this thing. One thing of note: she is clueless about car maintenance and honestly has no idea what has or has not been done to her car.
  2. Nov 15, 2014 at 10:15 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Nov 15, 2014 at 10:17 AM
    T4RFTMFW
  4. Nov 15, 2014 at 10:30 AM
    Madjik_Man
    Kind of what I suspected.... sadly no real solution/information.
    I'll flush her brake lines first and see if that helps.
  5. Nov 15, 2014 at 10:56 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'm thinking it is b/c you live at high altitude..perhaps the booster or a vacuum issue.
    How long has she had the car? How long has it happened? Has she done anything to it since it first happened?
    I'd also guess you may have old brake fluid. If the fluid has attracted water it could freeze. Wouldn't hurt to flush the system at that age anyways.
  6. Nov 15, 2014 at 11:13 AM
    Madjik_Man
    From reading those links (and others) could be. Anything obvious to look for or diagnose?
    I think she's had it 5 years. My best guess is: no. She's not much of a car maintenance kind of person. I'm slowly changing that.
    Will be my first step.
  7. Nov 15, 2014 at 3:10 PM
    ABA180
    East Bridgewater MA
    I live south of Boston MA and I've heard of the brake fluid causing this issue over the years..probably could use it anyway at this point is my guess.
  8. Nov 15, 2014 at 3:26 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Probably water in the brake fluid. Good practice is to flush the brake hydraulic system every 40k miles.
  9. Nov 16, 2014 at 8:07 AM
    Madjik_Man
    I asked her if she's ever had the brake fluid changed, as far as she knows. Negative.
    I asked her if she's ever had work done on the brakes since owning the car. Negative.
    I hope it's just old brake fluid.
  10. Nov 16, 2014 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like a vacuum line is cracked or something.
