Help me build my lift... Please
Discussion in 'Suspension' started by ccoorreeyy, Aug 22, 2009.
  1. Aug 22, 2009 at 3:32 PM
    ccoorreeyy
    ccoorreeyy [OP] www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    Hey TW,
    I'm really interested in getting a lift for real now. I have about 500 bucks and I know that's not enough to get a really good lift, but I figure it's a start.
    I was thinking about getting new billy 5100's (front and back). Is that enough to start? Can I get those and install without problems? I'm looking for 2 - 3" of height. I think that's going to cost about 400. So, I have about 100 bucks left over. Should I wait till I get some more cash?
    I'm so stupid when it comes to this stuff to excuse my ignorance. :D
    Any help is much appreciated!
    C
  2. Aug 22, 2009 at 3:35 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    You are going to need some blocks or an AAL for the back. I say AAL and that runs $60-$100.
  3. Aug 22, 2009 at 3:40 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    well you're going to want to get bigger tires too; and with new tires you probably might want to get new wheels...lifting your truck aint cheap man! save the money
  4. Aug 22, 2009 at 3:40 PM
    ccoorreeyy
    Corey
  5. Aug 22, 2009 at 3:42 PM
    ccoorreeyy
    Corey
    Well, I'm getting BFG TA KO's in the next couple of months. Could I ride my stock tires with a lift for a little bit? Would I run into problems?
  6. Aug 22, 2009 at 3:49 PM
    topgun155
    Zack
    The difference between the two is whether or not you have the TSB 4 leaf pack. One is made for the TSB springs and the other is for those who haven't had the TSB performed on their truck. Also you can use your stock ttires on with a lift. Most prefer to have tires for their looks. Also look at UCA that wil fix your alignment. at 3in you don't have to have them.
  7. Aug 22, 2009 at 3:51 PM
    ccoorreeyy
    Corey
    Are Coils needed?
  8. Aug 22, 2009 at 4:01 PM
    topgun155
    Zack
    With the 5100 you don't need them. The only way you can use them is to use the 5100 on their stock setting. Really just a waste of money to buy both.
  9. Aug 22, 2009 at 4:01 PM
    ccoorreeyy
    Corey
  10. Aug 22, 2009 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Before deciding on a lift, what are you doing with your truck? Hard off road? No off road? Mild....Medium????
  11. Aug 22, 2009 at 4:08 PM
    topgun155
    Zack
  12. Aug 22, 2009 at 4:14 PM
    ccoorreeyy
    Corey
    I've been doing mild-medium off-roading. Nothing to crazy.
  13. Aug 22, 2009 at 4:15 PM
    ccoorreeyy
    Corey
    So it would make more since for me to get this $299 set then to get the 5100's and the AAL, right?
    Cheaper. :D
  14. Aug 22, 2009 at 4:28 PM
    ccoorreeyy
    Corey
    Wow. I'm really retarded. What's TSB stand for?
  15. Aug 22, 2009 at 4:30 PM
    topgun155
    Zack
    If you want this set up then you don't need the 5100. you can get them to improve ride quality, but they must remain on the stock setting. In this package it is the coils that will do the lifting for you. Also this package will come with the AAL they are the little flat peices with a bow in them.
  16. Aug 22, 2009 at 4:34 PM
    topgun155
    Zack
  17. Aug 22, 2009 at 4:41 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Trust me when I say this; save your money for the good stuff. All you're doing by trying to get away with just the 5100 billys is setting yourself up for a loss of money. About a month or two after you install your 5100 you'll be unhappy with height and wish you would have gone bigger from the getgo. Stop spending money on beer and going out for a couple of months and you'll have saved enough for a good set. The way the economy is you can get a set of used coilovers for a good price either on craigslist or on this board. Example: I got a set of SAW's 2.5 for $540, set of billys for the rears and a set of aal's $330 and installed everything myself. P.S. tsb= technical service bulletin.
  18. Aug 22, 2009 at 4:43 PM
    ccoorreeyy
    Corey
    I can only go 3" because I won't fit in my garage. You have a 6" lift?
  19. Aug 22, 2009 at 4:45 PM
    ccoorreeyy
    Corey
    Ok. Here's my shopping cart. I got the extra 5100's for the back of my truck because I think I need new ones. I bottom out with very little weight in my bed.
    Good? Anything else I need?
    BEST SELLER! 3" Lift With front coils & rear options
    Options: Standard 884 coils OME3-05-AL $299.99 $299.99
    Rear Bilstein Shocks 05 & UP TacomaRTAC-BIL $199.99 $199.99
    Subtotal: $499.98
    Total: $499.98
  20. Aug 22, 2009 at 4:47 PM
    topgun155
    Zack
    Oh Yea. Since your 4x4 you will need a front diff drop kit. I think its like $30 and super easy to install, But don't quote me on this I haven't looked into this. 2wd:(.
