Help me buy a mountain bike!
Discussion in 'Sports, Hobbies & Interests' started by PELLEY, Mar 11, 2013.
  1. Mar 12, 2013 at 9:42 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Just to add to wallmart type bikes and overall quality of department store bikes.
    I just about thrashed one on a single 22km XC trail in the mountains in Jasper a few years ago. Quite a bit of roots and singletrack on that one though. Besides not having enough braking power, terrible handling, poor shifting performance and useless suspension, everything was loose and rattling by the end of the day. The next time out there, I broke of the pedal before I got back to the truck.
    Some more options to consider from www.pricepoint.com. I have not ridden one ever so just judging by looking at specs.
    http://www.pricepoint.com/detail/22...0-SLX-Dual-Suspension-4inch-Mountain-Bike.htm
    http://www.pricepoint.com/detail/22...0--XT-Dual-Suspension-4inch-Mountain-Bike.htm
    They have a Demo version of this one for $1399.
  2. Mar 12, 2013 at 9:43 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
  3. Mar 12, 2013 at 9:46 AM
    andoskyy
    andoskyy Well-Known Member
    If you want to buy new, you won't find any better components than this at your price point
    http://www.fezzari.com/full-suspension-cross-country/wiki-peak
    my brother has a Fezzari and they're very nice bikes. not too well known, but take a look online for reviews...they're all good.
    Another suggestion would be looking for leftover stock at local bike shops. Might be able to pick up a 2011 or 2012 new for a few hundred less than the new model.
    Good luck!
  4. Mar 12, 2013 at 9:51 AM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    This^^ go on there and look in the buy/sell section and you can find local deals, if you dont mind used you can find some great bikes for cheap
  5. Mar 12, 2013 at 9:53 AM
    PELLEY
    PELLEY [OP] Well-Known Member
    Man you guys just keep the suggestions coming, thank you so much for the help!!! So many options.
    So I am leaning used, with nicer parts over new with slightly cheaper parts. I assume just like a truck, a used bike with a good tune up and good maintenance will work just like new. Unless someone says otherwise...
    Lets see if I am tracking right. Found this used giant on pinkbike. In my budget, and seems to have the right stuff. Only thing is it doesn't say frame size, I would need the large...
    http://www.pinkbike.com/buysell/1267678/
  6. Mar 12, 2013 at 9:55 AM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    Its a large frame, 19" and im sure you could get him down from 1000 those are older frames i believe
  7. Mar 12, 2013 at 10:45 AM
    PELLEY
    Ya I just saw they were from 2003... Question is, is an older bike like that worth the savings of $300 to $400...
  8. Mar 12, 2013 at 1:07 PM
    scottg918514
    scottg918514 Well-Known Member
    2013 DC, TRD 6-spd Manual, 4wd
    This looks promising. High mid-level components, new and can get the size you want. I'm 6.0' even and ride a large in hardtail 29er. I used to ride med, but started have back issues. I still ride a med in my suspension 29er.
    [FONT=.HelveticaNeueUI]http://item.mobileweb.ebay.com/viewitem?itemId=400432366788[/FONT]</SPAN>
  9. Mar 12, 2013 at 1:14 PM
    andoskyy
    A word of advice would be to buy a bike for the frame. Get the best frame you can afford. Components will break...cheap or top of the line.
    When they break...replace them with good stuff.
    Properly tuned, almost all mid level and up components will shift and stop you the same...the difference between a SRAM x7 and SRAM x0 is just weight.
  10. Mar 12, 2013 at 1:15 PM
    PELLEY
    I am really feeling like I want to full suspension. A few people have mentioned the hard tails, but no reasoning as to why I would want that over full...
  11. Mar 12, 2013 at 1:16 PM
    PELLEY
    Thanks for the good advice!!
  12. Mar 12, 2013 at 1:18 PM
    PELLEY
    So I am now leaning towards the Trek Fuel EX series. Would like to get EX 7 or better, but even the 5 doesn't look too bad. I was looking at the prices of derailers and some of those parts and they seem to be reasonable if I want to upgrade later when they need replacing. I like the many mentions of buy a great frame. Just trying to pin down at what point do I need to consider the shock supplied as adequite or shitty. Like the difference between the EX 5 and 7 is the fox or rock shoxs... Still thinking used if I can find one, or last years model...
  13. Mar 12, 2013 at 1:24 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Regarding the 29er, you only want the 29er if you are going to be mostly xc. They wont handle the jumps as well as a 26er or 650B. The 2x10 new 650B is the thing nowadays however your not going to find anything for less than 1500 in that regards.
    As for bikes look at KHS. Depends on what bike you want i.e. xc or AM but the below link you could pry get the bike brand new last years model for 1000 or less OTD from an msrp of 1350. KHS has terrible marketing so they are stuck with bikes and are always having closeouts. Comes with decent components and uses the same DW link as most other more expensive bikes. You can also slowly upgrade parts. If your wanting new I would contact a bike shop and see what clearance models they can get.
    Otherwise pinkbike and MTBR forums are your best bet.
    http://khsbicycles.com/bikes/2013-khs-models/xc-104/
  14. Mar 12, 2013 at 1:27 PM
    2ski4life7
    Seattle WA
    Trek has great deals in their online store but the better deals I think you have to buy in the store. Rock shox I think is getting to be on par with fox since they are owned by sram. I always picked fox but the new fox 34 and 36 forks feel like crap to me. Another thing, you wont notice a large difference in the shocks/forks until you get a lot of seat time on the bike. Maybe coming from a dirtbike background you might notice the differences faster than someone just learning.
  15. Mar 12, 2013 at 1:36 PM
    #35
    PELLEY
    Thanks for the tip. I know I probably won't notice a whole lot at first. My last full suspension bike was about 10 years old and had cheap parts so I am sure anything will feel awesome. I have been looking on Craigslist, there are a ton of EX 5 and a few EX 8's on there and within my budget. I am thinking this is my route unless someone wants to derail me and send me another way, haha. Don't worry, it's already happened like 10 times since I started this thread...
  16. Mar 12, 2013 at 1:43 PM
    #36
    scottg918514
    1. Ur price range. Full sus more expensive, at ur price difficult to get a decent bike. My fs in $4k range, my ht in high $2k range.
    2. 29er bigger wheel/tire, more forgiving, not quite full sus but closer then 26 ht. especially if u get a steel frame.
    I ride my carbon ht 29er more than my fs 29er. I use my fs for extreme rock trails and long trips with unknowns. Also, ht easier clean and maintanance, so my primary bike this time of year.
  17. Mar 12, 2013 at 2:20 PM
    #37
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I really like my ex8 the main difference between pre 2012 or 13(I don't remember which) ex 8 and ex <8 is that they don't have the DRCV rear shock. The ex 8 climbs great and descends great. It's a fun bike with pretty good geometry. I have no problems with rocks although extra travel would be nice but it will be fine for a lot of things. The thing I like is that is beefier than a straight up XC bike but not as big as an all mountain bike. Over all it's a good choice especially for getting back on the bike
  18. Mar 12, 2013 at 3:34 PM
    #38
    PELLEY
  19. Mar 12, 2013 at 4:58 PM
    #39
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    My old 29er hardtail was the smoothest bike I've ridden overall. A full suspension is great for very bumpy terrain, but the 29er handled everything I put through like a champ. Hills, trails, jumps, streets, curbs. And the tires could take 80psi so on road manners were amazing at that pressure.
