Help me choose my Icons. Resi? Or not to Resi?
Discussion in 'Suspension' started by RogueTRD, Jun 19, 2015.
Which option?
Poll closed Jun 29, 2015.
  1. Icon extended travel coil overs and rear shocks, no resi.
    2 vote(s)
    22.2%
  2. Icon extended travel coil overs RR and non resi rear shocks.
    0 vote(s)
    0.0%
  3. Icon extended travel RR coil overs and RR rear shocks.
    6 vote(s)
    66.7%
  4. Other... And why?
    1 vote(s)
    11.1%
  1. Jun 19, 2015 at 7:11 PM
    RogueTRD
    RogueTRD [OP] Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    So I have a little dilemma I would like some input on. I currently have a full OME setup ony truck (887s, Dakars, and nitrochargers all around) and now that I have a lot of extra weight that I'm packing around and my 887s sagging a bit not being enough to handle the weight I was originally considering 886s with a top plate spacer. After my experiences in Moab and realizing I want a little more capable suspension I am looking at getting some Icon extended travel coilovers, rear extended travel shocks and some Wheelers Superbumps. I initially was going to go for broke (literally) and get extended travel RR coilovers with 700 lb springs and extended travel 2.0 RR rear shocks, but now that I'm thinking about it... I don't do a ton of high speed runs but for what I do, the OME stuff is not enough. The way I see it I have a couple options...
    1. Get the front and rear Icons without resi and use the money I save to get a new set of tires (going up a size).
    2. Get the fronts with resi and non resi rears and still get tires albeit less expensive ones.
    3. Say screw it and get the front and rear RR's so I can't say I regret not getting them and for pure cool factor. Get tires when my current ones wear out.
    4. Go another route, and why?
  2. Jun 19, 2015 at 7:30 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    if you run hard for an extended amount of time and/or if you live in an area where it gets hot as balls, get RR. I've been in my friends 4runner when his non resi's faded and it hit hard with no indication. Only thing to do after that is take it slow or pull over and let them cool. I decided RR's for my rig after that trip. And it was only 80's or low 90's that day.
    RogueTRD[OP] likes this.
  3. Jun 19, 2015 at 7:35 PM
    GSHEP4
    GSHEP4 Well-Known Member
    Lehighton, PA
    2014 spruce mica sport
    s/c,fluid film, bug shield, window vents, under hood lights, bed lights, tailgate reinforcement, and more.
    68vert hit the nail on the head.
  4. Jun 19, 2015 at 7:42 PM
    RogueTRD
    Cade
    So. Oregon
    It gets pretty damn hot here in Southern Oregon, but probably nothing compared to AZ. We've already been over 100 here a couple times this summer. I just noticed when running some fast sandy washes/washboards/dirt roads in Moab my OME shocks just weren't up to the task. Here at home we don't have the same terrain but I plan on traveling all over western U.S. Off roading and camping so I dunno.
  5. Jun 21, 2015 at 2:32 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    The standard middle of the road approach is non-RR 2.5 fronts and RR 2.0 rears. The fronts being 2.5 already have plenty of oil volume and a larger surface area to dissipate heat. The rear 2.0 has less volume and so the RR helps with that and getting a RR on the rear 2.0 isn't that much more money. I've read a number of build threads with from people this setup who run twenty miles or more of washboard without issue. Many of these same builds came from OME and say the difference going to ICON is night and day for washboard runs as well.
    Remember, the OME being a twin tube design dissipates heat a lot less effectively than a mono-tube design and has lower oil volume as well. So going to the ICON will already help a lot with fade compared to the OME.
    ckeene9 and RogueTRD[OP] like this.
  6. Jun 21, 2015 at 2:54 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not only will you enjoy the benefits of extended play time without cavitation of the shock oil (fade), but you will also experience longer service intervals. I have ran the piss out of my shocks and upon having to rebuild one due to defective seals, the oil that came out of it was astoundingly clean.
    Do yourself a favor and get yourself the reservoirs even if you don't run hard right now. They will have the ability to keep up with your wheeling if you live in a hot environment, stay cleaner longer, but they will also be prepared for the hammering you may give them if you ever decide you want to push your rig's limits even further. Of course at that point you will want to consider upgrading other pieces of the suspension, but I digress.
  7. Jun 21, 2015 at 3:04 PM
    RogueTRD
    Cade
    So. Oregon
    Thanks for the input dudes. I am probably just gonna go RR all around and forgo getting tires for the time being. Picking them up on Wed.
    ckeene9 likes this.
  8. Jun 24, 2015 at 9:30 PM
    RogueTRD
    Cade
    So. Oregon
    Picked them up today. RR all around
    DVexile and DirtyTerp like this.
  9. Jun 26, 2015 at 7:55 AM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    good choice!!!! You will be glad that you spent the extra and installed RR all around.
