Help Me Chose Rear Leaf Setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stubbs07Tacoma, May 1, 2015.
Dakar or All Pro expadition leafs
  1. OME Dakar
    33.3%
  2. All Pro Expedition Leaf Springs
    66.7%
  1. May 1, 2015 at 12:00 PM
    Stubbs07Tacoma
    Stubbs07Tacoma [OP] Toyota Veteran
    Blake
    EXPO in the making All Pro Expo Leafs PelfreyBilt front bumper full hoops 20 Inch led bar in bumper AVEC pods for fogs Warn 9500 Front suspension currently being redone
    07 Taco 4x4, Has a 6 Inch lift as of now ( came with the truck don't judge me) Im going to be putting on a rear bumper in the future so they need to be able to handle the weight, So help me by voting, All Pro or OME?
  2. May 1, 2015 at 12:06 PM
    ATLien
    ATLien Well-Known Member
    Portland
    2013 DCSB SR5
    Money Pit
    Are you trying to keep the 6" lift? Each of those is ~3" so you'd need blocks (bad) or a custom leaf pack to stay at 6"
  3. May 1, 2015 at 12:08 PM
    Stubbs07Tacoma
    Blake
    Should have mentioned that im gonna ditch the DB lift and go for a MT setup on the front
  4. May 1, 2015 at 4:01 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    I've had both OME and the AP's. IMHO, the OME's aren't even close. The AP's handle heavier loads better in off-road conditions, give a better ride, and have more articulation. The down side is that you need longer shocks/brake lines and they definitely rust.
  5. May 2, 2015 at 8:52 AM
    Stubbs07Tacoma
    Blake
    luckily I already have a 6 inch lift on the back so it should be a direct swap, how do you fix the rust issue?
  6. May 2, 2015 at 10:10 AM
    Stubbs07Tacoma
    Blake
    question, Will the expos make the rear sit too high if I want a LT setup in the front?
  7. May 2, 2015 at 7:52 PM
    GroupW
    Mark
    Arizona
    Red TX
    No extra leaf. I've had second hand experience with that on a friend's truck...carries more weight, but rougher than a cob and no improvement in articulation. You're right though. It depends on what you want...and like. My next set might be some custom Alcan's. The AP's have a lot of life in them though.
    As for the rust thing...the Navy taught me to scrape and paint.
  8. May 2, 2015 at 7:58 PM
    SjTacoSharks
    SjTacoSharks Well-Known Member
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    Sorry to jack your thread OP but I was wondering the same thing. Ill be running Kings ext travel in the front and don't know what I should do with the rear. I was thinking about the Dakars (possible take one of the leafs off as i don't load the bed much), superbumps, fox 2.0 resi for 3.5 to 5" lift, and the relentless u bolt flip. Let me know what you guys think
