Help me decide 265/70/16 or 265/75/16?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Dec 9, 2024.
  1. Dec 9, 2024 at 12:31 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I think I nailed down the tire. Local shop has Toyo Open Country ATII/SL in stock.
    I can't decide between sizes. I am one to always go with stock size since I am a conformist...BUT I like the look of bigger tires. I just don't want to mess with any issues that might arise. So I'm wishy washy.
    I would like to upgrade to gunmetal TRD wheels but don't have the money right now so will stay stock OR rims.
    cthoma70 likes this.
  2. Dec 9, 2024 at 12:40 PM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    I recently retired my stock tires for a set of 265/75/16 Cooper Discoverer Road + Trail AT, and haven't noticed any negatives or benefits in the ~1500 miles I've put on them. My truck drives the same. The size doesn't even look that different to me.
    Hopefully that sweet extra 1/2" of ground clearance comes in handy this summer when I hit some trails :cool:
  3. Dec 9, 2024 at 12:42 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    75's. Slight mileage drop. Never had issues with rubbing.
    TacoManOne likes this.
  4. Dec 9, 2024 at 3:19 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    It's actually 1" taller and a no brainer. Won't make it succeed over obstacles the you previously couldn't and you most likely won't note the MPG hit either. Speedo will display slightly more accurate based on what others have reported.
    I'm more than likely going with that size also.
  5. Dec 9, 2024 at 5:58 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Do not buy the ATII, buy the ATIII it is an updated superior tire.
    Yes, 265-75-16.
  6. Dec 9, 2024 at 5:59 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    265/75r16 no doubt
    02Duck and RIX TUX like this.
  7. Dec 9, 2024 at 6:01 PM
    Big Cole
    Big Cole Well-Known Member
    I lost 3 MPG when up sizing to the 275 75 16. They do look significantly better though especially on a long bed.
    NOLAN_3G4R likes this.
  8. Dec 9, 2024 at 6:10 PM
    forana
    Kaneohe, Hawaii
    It was a typo, ATIII
    RIX TUX and eurowner like this.
  9. Dec 9, 2024 at 6:31 PM
    Aaron O.
    Aaron O. Well-Known Member
    Aaron
    Denver, CO
    2023 Tacoma Off Road DCLB
    Swampers. Any size will be fine.
  10. Dec 9, 2024 at 6:34 PM
    joebwan
    joebwan Active Member
    2017 TRD OR White & 2017 TRD Pro Cement
    75’s are a no brainer. A little higher, look better, no performance loss. They have been on my 2017 for 3 years.
    ToyodaSun likes this.
  11. Dec 9, 2024 at 7:08 PM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    6112/5160, Deaver J66, Wildpeaks, OTT, Sliders, Armor
    Part of the mileage “drop” is that you’re running a tire with a larger circumference. You go farther for each tire rotation. The difference for these two sizes is 3,3% meaning your mileage (and speedometer) are “off” by 3,3%. So if you were getting 17,5 mpg before and now you only get 17 mpg it’s actually the same, adjusted for circumference and actual distance traveled.
    RyanL, 1994SR54x4 and TheWildMan like this.
  12. Dec 9, 2024 at 8:03 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Just to keep in mind, a good friend of mine wanted the new BFG KO3 for his Ram, called the local BigO shop which said they had them in stock. Sadly after he paid and got home, he noticed they installed the older KO2. They fought him about it and he is stuck with them.
  13. Dec 9, 2024 at 8:05 PM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    Csoth7 and PondScum like this.
  14. Dec 9, 2024 at 8:33 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    be a wild man.....show off that extra inch
  15. Dec 9, 2024 at 10:03 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    That extra inch is where all the fun happens!
    TacoGranny and RIX TUX[QUOTED] like this.
  16. Dec 9, 2024 at 10:21 PM
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    The cheaper one. You won’t notice a difference.
    Jaredius, StandardTaco and PondScum like this.
  17. Dec 10, 2024 at 5:58 AM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    He’s not wrong
    Jaredius and SoCal_Erik[QUOTED] like this.
  18. Dec 10, 2024 at 6:23 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    "Federal Regulation: 49 CFR §393.82, effective 2005, requires a car’s speedometer to be accurate to within a plus or minus 5 mph at a speed of 50 mph."
    Some of our trucks are probably off from the get go.
    OnHartung'sRoad and 69 Jim like this.
  19. Dec 10, 2024 at 7:11 AM
    PondScum
    PondScum OG 303
    Colorado
    2023 Trail Edition
    Agreed that there’s likely a margin of error with a speedometer. But it’s the odometer, not speedometer, that’s used for calculating gas mileage. Speed is a product of mileage and time.
    I’m just saying that changing tire size and observing a drop in mpg is not necessarily due to a tire being less fuel efficient. Some/all of the difference may simply be a math problem. Also, any measurement error would remain consistent for a single vehicle so the only variable is the tire (size, weight, tread pattern, rubber compound, etc.).
    bkhlrTaco's[QUOTED] likes this.
  20. Dec 10, 2024 at 7:13 AM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Go with the 75 especially if you are going to change up your shocks and lift later.
    Jim727386 likes this.
