Help me decide between Spindles and OME
Discussion in 'Suspension' started by Incognito, Oct 24, 2011.
Which option?
Poll closed Mar 22, 2012.
  1. Spindles
    75.7%
  2. OME
    25.7%
  1. Oct 24, 2011 at 7:33 PM
    Incognito
    Incognito [OP] No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Hey guys,
    I pretty much have 2 options I'm thinking about going with, and your opinions are much appreciated.
    Option 1:
    Camburg Spindles
    OME Dakar's
    315/70/17 Dynapro ATM's
    XD Addicts
    Ext. brake lines
    Bilstein 5125's (rear)
    Bilstein 5100's (front)
    Total cost: $2950 not including shipping for lift (tires are shipped)
    Option 2:
    OME Complete kit
    Light Racing UCA's
    33" BFG AT's (or Duratracs)
    XD Addicts
    Total cost: $2538 not including shipping (tires are shipped)
    Sway me one way or the other.
    EDIT: Added poll.
  2. Oct 24, 2011 at 7:40 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    Spindles love them...option 1 will be bigger and look so much better IMO. And being $400 more in the big picture is nothing.
  3. Oct 24, 2011 at 7:41 PM
    Incognito
    VA
    Definitely leaning that direction, thanks for the positive reinforcement, lol. Where did you get yours installed at and how much did it run, if you don't mind me asking.
  4. Oct 24, 2011 at 7:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Option one Colton.
  5. Oct 24, 2011 at 8:31 PM
    Tat2dTaco
    Tat2dTaco He who breaks things.
    Ricker
    San Antonio, TX
    05 SWB Prerunner
    Camburg Spindles All-Pro Expo Leafs Bilstein 5100s and 7100s DTF Pre-Runner Bumper Tons of other crap
    Spindles!
  6. Oct 24, 2011 at 8:47 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    the stance and finsh of a set of spindles is unmatchable by any other lift
  7. Oct 24, 2011 at 8:48 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Everything was about 3.5k the install was $400 i believe. I got my lift installed at a local offroad place (B & R offroad). I have compared and the spindle lift was much cheaper to install for shops than option 2 with the UCA's. No negative things about the spindles I love it!
  8. Oct 24, 2011 at 9:39 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Everything is self installable. Save some money and learn about the truck:D
  9. Oct 25, 2011 at 12:44 PM
    Incognito
    VA
    Nice, thanks for the info. I emailed a couple shops up this way about getting some quotes.
    I would but I'm hesitant to mess with bleeding the brakes and all that shit. I'd be installing the rear leaf pack and the front Bilsteins though.
  10. Oct 25, 2011 at 12:46 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Bleeding the brakes is a piece of cake! By far the easiest part of the process. If that's all that's stopping you, I'd say do the install yourself.
    I voted OME. Spindles may look better but the ride will be better by completely replacing the entire suspension rather than using stock coils. I like the stiffer coils, I think they make the truck ride and handle much better.
  11. Oct 25, 2011 at 11:01 PM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island--->Oahu, Hawaii
    10 AC TRD OR 4x4 BSP; 08 Reg Cab 5 spd 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Smoked Eagle Eyes Ebay LED Tails | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    +1 for spindles!
  12. Oct 25, 2011 at 11:02 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Spindles for sure
  13. Oct 27, 2011 at 7:46 AM
    Incognito
    VA
    Bump, thanks for the input so far.
  14. Oct 27, 2011 at 7:50 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You don't tell us how you'll be using the truck...
  15. Oct 27, 2011 at 7:51 AM
    Pugga
    Massachusetts
    F-150 Mod
    I gotta ask, for my own education, why is everyone recommending spindles vs. upgrading the coil/struts? My method of thinking is, I'd rather have a heavier coil so the truck doesn't roll as much in corners or dive as much under heavy braking vs just having additional height on stock suspension. I don't have a prerunner and probably never will (need 4x4 for snow) and not trying to start a crapstorm, I'm only asking for my own knowledge.
    Also not trying to threadjack but I think the responses would be relevant to your original question.
  16. Oct 27, 2011 at 8:00 AM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    Personal recommendation: I've never been a fan of spindles on stock suspensions, I'd much rather upgrade to full coilovers first.
    There are plenty of good CO's at the $1000 range to choose from and will give you 3" compare to the 4" spindles.
    Also on the LR UCA: For the money spent, why are you going back to ball joint instead of to uniball.
    If you're already forking out $450 or so, what's another $150? LOL
    Function over form, but hey its your truck and your money. :thumbsup:
  17. Oct 27, 2011 at 9:48 AM
    Incognito
    VA
    Mild/moderate trails, hunting trails, hauling firewood, etc. nothing serious, and for looks also. (I am a Prerunner, mind you :anonymous: )
    I mainly researched spindles because of the height aspect. I love the look of 4-5" of lift on the DCLB. Not too far down the road I would go with Eibach coils on the 5100's up front, and those would stiffen up the front. I'm not sure I could benefit from a high-dollar coilover based on what I'd be using my truck for, EVEN though I'd be getting spindles. IMO, Eibachs would work out great with the 5100's set at 0, and that would make the front stiffer but gain the amount of lift I'd like.
    I might be looking at the Maxtrac spindles which would run $450, but still need to get some more info on them.
    35's would be nice... :D
    I got a quote from a shop today for $400 for everything installed with an alignment included.
    I don't think I'd get the use out of $1000 coilovers based on what I use my truck for though. The OME kit would fit my needs perfectly should I go with a 3" kit. I just wouldn't get my money out of a high end suspension up front.
    As for the UCA's, hearing good things about them with alignments plus being cost effective for my application just made them a good choice IMO. I'm definitely open to other suggestions though.
  18. Oct 27, 2011 at 10:05 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Maxtrac spindles. Eibach coils on 5100s. OME dakars w/2" block or all pro expos
  19. Oct 27, 2011 at 10:10 AM
    Pugga
    Massachusetts
    F-150 Mod
    Why would you buy a new leaf pack and still use a lift block?? :confused:
  20. Oct 27, 2011 at 10:13 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Because he would still hace the bro lean.
    Or he could just get a set of custom heigth alcan leafs
