Help me decide on a lift!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverTacoZack, Aug 12, 2011.
  1. Aug 12, 2011 at 5:30 PM
    SilverTacoZack
    SilverTacoZack [OP] Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    Ok guys, due to discovering some savings bonds I didn't know I still had, I now finally have the money for a lift. Problem is, there are just SO many different options. I have a prerunner, so I know technically drop bracket lifts aren't required to get big lift, but they do seem to still be a good option. My budget is basically 1500 dollars, but I'm more than likely going to have to pay to have this installed at a shop unless I can get a forum member to help with the install or something. My goals for this lift are the following:
    1. At least 4 inches of lift.
    2. Must be tough enough for moderate offroading (i.e. no rock crawling but maybe some mud and trails)
    3. Has to work with VSC.
    What would be your best recommendation?
  2. Aug 12, 2011 at 5:33 PM
    donaldwagner
    donaldwagner -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
    2 1/2'' bilsteins and body lift
  3. Aug 12, 2011 at 5:39 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  4. Aug 12, 2011 at 5:39 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    your joking right....
  5. Aug 12, 2011 at 5:57 PM
    YoungGunz23
    YoungGunz23 Well-Known Member
    Caleb
    Monroe Louisiana
    08 TRD Off Road
    3" fabtech lift 33" federals
    go with a fabtech body lift or go with a suspension with bilstien 5100's
  6. Aug 12, 2011 at 5:58 PM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    I have heavily considering the Camburg 4 inch spindles in the front paired with an All Pro Expedition 3 inch leaf pack in the rear. But I am concerned about the spindle's compatibility with VSC. Virtually all the stuff about the Camburgs shows them only being good for up to 2009 (pre-VSC) trucks.
  7. Aug 13, 2011 at 4:30 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Can anyone confirm spindles will be OK on a 2010 VSC equipped truck? I'd really like to pull the trigger and order Camburg Spindles, Extended Brake Lines, All Pro Expo Leafs, and Billstein 5150's, but I'm currently held back by this unknown information.
  8. Aug 13, 2011 at 4:42 AM
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma TRD Off Road Hybrid
    285/70/17 Nitto Ridge Grapplers, RRW wheels 17 x 8.5, Wescott designs pre collar lift, rough country power side steps, Truxedo pro x15 soft roll up bed cover, OEM bed mat, OEM bed swing out box, OEM Trd pro front skid plate, aftermarket pro grill, diode dynamics led fog lights, OEM sport hood, PPF and tint,
    fabtech
  9. Aug 13, 2011 at 4:49 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    spindles... BEST choice for a Prerunner...everything else will be inferior (besides LT)
  10. Aug 13, 2011 at 4:56 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Yeah I've come to that conclusion because I can do those now with the all pro leafs in the back, and be running my stock front suspension. Later when I save up for 35 tires I could always add new C'O's in the front for 2 inchs more lift and a 1 inch block in the rear to get me to 6 inchs.
    BUT...no one seems to be able to confirm the VSC compatibility of these things :confused:
  11. Aug 13, 2011 at 10:28 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You said it works up to and including 09? Cuz 09 has vsc so it should work for yours then.
  12. Aug 13, 2011 at 10:34 AM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    Your best bet would be to call camburg and check with them...
  13. Aug 13, 2011 at 10:53 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Well I did manage to find some trucks on this site that were '10 and '11 model year Tacomas with spindles, and they made no mention of any serious issues. I'm going to pull the trigger on these monday, as well as some Allpro Expedition 3 inch springs, and extended break lines and 5150 shocks. I think this will be a very nice upgrade. Only problem is i'm still a bit worried about doing the install. The rear leafs and shocks I am pretty comfortable with, the front end spindle install however seems pretty involved. I don't want to pay 500 dollars for a shop to do what I COULD do myself, though.
  14. Aug 13, 2011 at 1:21 PM
    04taco2wd
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    Just find some buddies that are willing to help and buy them beer. And take your time, you'll be fine.
  15. Aug 14, 2011 at 3:57 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    its is involved but straight forward... you'll just be disassembling you front suspension and adding in new spindles... easy...time consuming...but easy...plug and play
  16. Aug 14, 2011 at 7:07 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Well I am going to attempt it. I am just picturing some worst case scenario where my truck is stuck on jack stands in my garage because I got stuck somewhere in the process and can't get it back together right. I am sure though, if that happens i will post pics and TW will help me through it :cool:
