Help Me Decide... Ridge Grapplers or Wildpeaks??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RYE793, Apr 20, 2023.
  1. Apr 21, 2023 at 2:34 AM
    Molina67
    Molina67 Well-Known Member
    Ken
    2022 Tacoma SR5
    265/65R17x9 12mm offset Wildpeaks
  2. Apr 21, 2023 at 5:47 AM
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    My personal experience with the Nitto’s was horrible performance in rain.
    never had wild peaks
    I’m back to bfg at’s And Toyo at3 both Just seem to last the longest and perform the best
    auskip07 likes this.
  3. Apr 21, 2023 at 6:29 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Toyo AT3.
    Ski
  4. Apr 21, 2023 at 6:40 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I just did ridge grapplers last week. They replaced a set of wildpeaks. I had balancing and dry rot issues with my peaks(many have reported the same). It took 3 tries to get them balanced right. Only my local Toyota dealer could get them to balance decent.
    These ridge grapplers balanced(not road force) fine the first try and provide a much smoother ride. Noise is about the same. Haven't tested them off road or in snow yet. Rain traction was fine. Imo the nitto is a better looking tire as well. Looks more aggressive.
    A friend of mine has the toyos and loves them. Great tire as well, just not as aggressive looking.
  5. Apr 21, 2023 at 6:42 AM
    fourfourone
    Very false. The nitto is a very different tire from cost, construction, weight etc. Sounds like you are the one who needs to do the research.
  6. Apr 21, 2023 at 8:28 AM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    The difference in the two tires should be clear and easy to tell based on the specs posted on the 7,000 tire websites on the internet, asking random strangers for advice on the most talked about topic here is insane. I'll leave you guys to argue about every tiny detail between them and go drive mine in the mountains.
  7. Apr 21, 2023 at 8:39 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I personally think Wildpeaks are flaming garbage and would not recommend them at all. Many have had good experiences, but many have also had bad experiences. No experience with Ridge Grapplers, but I'd choose them over Wildpeaks. They are from the same parent company as Toyo anyways.
    I have been extremely pleased with Toyo ATIIIs, and I was decently pleased with General Grabber A/Tx. I have no intention of deviating from Toyo unless one of a few things happens: they’re discontinued, size i want isn’t available, quality goes down, or an option that compares and is proven to be better is released.
    DavesTaco68 likes this.
  8. Apr 21, 2023 at 8:44 AM
    RYE793
    RYE793 [OP] Well-Known Member
    2022 Lunar Rock SR5 Trail
    I appreciate your feedback on this and will be going with the Nitto's. What size are yours??
  9. Apr 21, 2023 at 8:55 AM
    RYE793
    As "insane" as I may have been to post this up, I have actually gotten a lot of helpful feedback. Isn't that what forums are for??
  10. Apr 21, 2023 at 9:32 AM
    fourfourone
    When did wildpeaks vs ridge grapplers become the most talked about topic on TW?
    Youve been a member for a few months. Get off your high horse lol.
    Asking people for advice is what forums are for....I don't get what point you are trying to make. Plus no one is arguing in this thread except for you.
    jackn7, PinStripes and Kolache007 like this.
  11. Apr 21, 2023 at 9:33 AM
    fourfourone
    265/75r16.
    RYE793[QUOTED][OP] likes this.
  12. Apr 21, 2023 at 9:39 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Well not really. Wildpeaks have the 3 peak snowflake rating.
    jackn7 and CaptainBart45 like this.
  13. Apr 21, 2023 at 9:45 AM
    fourfourone
    Or the drastically different tread pattern.
  14. Apr 21, 2023 at 10:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Same year, model and make jeeps. Same tire pressures. Jeep in front running BFG AT's, I'm running Nitto Ridge Grapplers. We did a special trip to figure out which one was better (for me). The ridge grappler had way more traction in every instance. In this vid, you can hear the BFG's struggling for grip vs. no struggling when I went over the same line.
    https://youtu.be/WCbZMNG5UrE
    TacoZmtn, Road_Warrior and PinStripes like this.
  15. Apr 21, 2023 at 10:09 AM
    #35
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    Depending on what load rating you get ; c or e, take a look at the weight of the tires... wildpeaks are fairly heavy in comparison to other tires
  16. Apr 21, 2023 at 10:09 AM
    #36
    fourfourone
    awesome share!
    Kolache007 and chris4x4[QUOTED] like this.
  17. Apr 21, 2023 at 6:53 PM
    #37
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Toyo or Wildpeak (my first choice) for ID weather?
    My Taco is moving to ID soon and need something that will work for the snow/rain there as opposed to SoCal. Had my mind made up for Wildpeaks to replace OEM Kevlar (garbage) but now I'm not sure?
    EDIT: No wheeling, mostly street duty AFAIK. Gifting the truck to my teenager for college.
  18. Apr 21, 2023 at 6:59 PM
    #38
    BLtheP
    Plano, TX
    Slightly better traction on WPs, but a much better quality tire overall with Toyo. The Toyos are not dangerous in wet climate, they are far better than many tires. I’d go toyo.
  19. Apr 21, 2023 at 7:14 PM
    #39
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I like my Toyo AT3s except for the mocking I get from friends and family. In the sl rating they are about the least aggressive looking at tire. I've got some folks who like to compare them to their LT rated mud tires and then ask if I'm due to replace my tires soon.
    They have been great in rain, solid on ice and not loud. They aren't MTs and don't clear mud particularly well but thats expected.
    Just be aware OP, if you are buying for looks and considering the at3 find one in real life to look at first. It's not bad it just isn't aggressive (from my peanut gallery)
  20. Apr 21, 2023 at 7:17 PM
    #40
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Yep, and I had now idea, until this last winter, that KO 2's have the 3 peak snowflake rating. Actually to be honest the KO2's did really good in the mixed snow rain and ice conditions that I wasn't expecting to put them through. I was extra careful for sure after hearing all the reports of how horrible they are in snow and rain and ice. I probably still have some people in Northern Utah cussing up a storm after driving behind me.
