Help me decide.. SL or E rated.. 245 or 265..?
Discussion in 'Wheels & Tires' started by dTed, Jul 25, 2021.
  1. Jul 25, 2021 at 7:28 PM
    dTed
    dTed [OP] Well-Known Member
    2013 DCLB SR5 4x4 MGM
    So I’m having a tough time deciding.
    I had all but decided that I wanted Continental TerrainContact AT in 245/75/16 (stock size). Then I realized that that size are only available in E rated.
    I’m 95% on-road, but I do live on a farm, and find some occasions where I need to go off-road and/or pull someone out that’s stuck. So I wanted something that’s great on-road, but also able off-road too. Seemed like the Terraincontact to me.
    So now it looks like I can either step up to the 265/70/16 to get the SL rated tire, or I can keep my stock size and get either the Cooper Discoverer AT3 or the Toyo Open Country AT3.
    I wanted the narrower tire because I think narrower tires are better in snow. That being said, I’m not sure I will like the heavier E rated tire.
    How big is the difference in ride/performance between SL rated and E rated tires?
  2. Jul 25, 2021 at 7:38 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyo AT3 will last the longest with least issues, I wish I had gotten them, the AT3 has proven to be a top tier tire like the old AT2 was.
    I have Cooper AT3 in SL 265/7016 and they simply aren't lasting as long as I had hoped, I wish I spent a bit more for more of a premium tire.
    I own 245/75R16 for winters and I can tell you there's not much difference in ride, but the 265's handle slightly better and look better.
    E rated is great for durability and toughness, but there is a slight take away with ride, usually have to run them at lower pressures to soften them up a bit. I've owned E rated and SL 265's.
  3. Jul 25, 2021 at 7:45 PM
    dTed
    Wow, good stuff there! Good to know about the Toyo’s holding up better.
    Is there a noticeable downgrade in performance as far as acceleration or cornering with an E rated tire? Can you “feel” the extra weight there?
    I do think the TerrainContact is a relatively light tire @ 50lbs, compared to 37 lbs for the SL rated Toyo AT3.
  4. Jul 25, 2021 at 7:48 PM
    Bishop84
    Typically the e rated is roughest on gravel roads and pot holes. It's why you run lower pressure on them, but they handle the abuse much better.
    I have experience with a lot of tires, but Conti is not a first choice for truck tires in the auto industry, they look like a solid tire and will last a long time. Any reason for selecting Conti tires? Experiences?
  5. Jul 25, 2021 at 7:52 PM
    dTed
    Not necessarily, I just watched some good reviews on YouTube and just in my searching on TireRack, they looked like a good mix of an AT tire that still has good on road and wet performance.
    I do live about 1/2 mile down a gravel lane, anything I should consider? I figured I would run lower pressures, does that have any affect on longevity?
  6. Jul 25, 2021 at 7:55 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    When I went from a sl to an e rated(Cooper st maxx)
    I could definetley feel a acceleration difference.The ride is a little rougher too..
    This is next set I’m going back to an SL or a c rated tire..
  7. Jul 25, 2021 at 7:58 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    If you are 95% on road and if the other 5% is light off road, there is no need for e rated tires. SL or C load are best.
    303tacoma and dTed[OP] like this.
  8. Jul 25, 2021 at 8:10 PM
    dTed
    I think that’s my main concern. I’m okay with a little rougher ride since I only have a 10 minute commute to work, but if I press the gas and I don’t have the same power as before, that might bother me on a daily basis.
    303tacoma[QUOTED] likes this.
  9. Jul 26, 2021 at 4:30 AM
    303tacoma
    Rebecca
    Ya it bothered me at first, after a while I didn’t even notice.
    Now if I go back to a Sl or C load,when I need a new set, this fall it’ll seem like I have more powero_O:D
    dTed[QUOTED][OP] likes this.
  10. Jul 26, 2021 at 4:33 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    You do not need E load. I bet hardly any Taco owners "need" it... unless you plan on slicing your tire sidewalls to ribbons on sharp rocks offroad regularly, the SL / C / P are fine. You literally can't load a Taco heavy enough to need an E tire for the weight capacity. I've many miles of fair offroad stuff and hauling a lot of weight / trailers on passenger rated AT tires and have never had a problem. I'm also in a similar use category as you: small rural property, 1/3 mile gravel drive, use truck for chores and extrication of stuck shit sometimes, but mainly paved roads, some leisure offroad. I just went with SL Wildpeaks in the 265/75 16 because an extra 1/2" of free lift don't hurt. Size and brand is personal preference though...
    crumbsXcountry likes this.
  11. Jul 26, 2021 at 5:02 AM
    dTed
    Oh I know for sure I don’t need E load. It was just the fact that the tire/size I wanted only comes in E load.
    I definitely think I’ve decided against E load though. Good to know from someone in a similar situation.
    Have any rubbing with the 265/75r16?
  12. Jul 26, 2021 at 7:21 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    No. They don't rub on stock suspension. It's the largest size (as per TW nerds) that'll fit. I also have a 1" lift though.
