Help me decide tire size
Discussion in 'Solid Axle Suspension' started by tlevan03, Mar 14, 2015.
  1. Mar 14, 2015 at 6:21 AM
    tlevan03
    tlevan03 [OP] Well-Known Member
    tad
    I thought this was the best spot for this question since I will be doing a SAS. I have the 4" trail gear front rings and 63" chevys for the rear, I will most likely add a leaf and longer shackles to level it out. Ive been seeing a lot of folks using the 3" TG springs and clearing 37"s will not issue. Im in a bind between choosing 37" or 40". They are pretty much the same price for the tires I've been looking at. Thanks in advance.
  2. Mar 14, 2015 at 3:50 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    If you just want a cool looking truck to drive to the mall and pick up bro-hoes from In-N-Out put 40's on it. If you actually want to wheel and not break shit, put 37's on it. Unless you have 1 tons, in which case you should know what size tires to go with :p
  3. Mar 26, 2015 at 1:39 AM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
