Help me decide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jimmyduff11, Sep 29, 2014.
  1. Sep 29, 2014 at 1:47 PM
    Jimmyduff11
    Jimmyduff11 [OP] Member
    Southern California
    2015 prerunner 4.0L short bed 4x2
    Stock as of right now.
  2. Sep 29, 2014 at 1:47 PM
    Jimmyduff11
    Southern California
    Also what do you think of the kit?
  3. Sep 29, 2014 at 1:51 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What type of use will this truck see? Hauling? Towing? Offroad? Mall crawling?
    Can't say I recommend (1) Rough Country and (2) a spacer lift.
  4. Sep 29, 2014 at 1:51 PM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    What he said. Don't go cheap on a brand new truck, or any truck for that matter if you can. Buy something a little better without spacers.
  5. Sep 29, 2014 at 1:51 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Complete junk IMHO. I would never put that crap on a $30,000 + truck.
    Lifting your Tacoma has nothing to do with what sized tire you can fit without rubbing. The geometry of the truck stays the same with 99% of lifts. Do some searching around for more info...there are hundreds of threads on lifts.
    All a lift like that one does is kill your down travel so when you hit a pothole your truck bottoms out in the rear (not good) and extends your LCA's farther than they should be so CV bind could be a real issue.
  6. Sep 29, 2014 at 2:00 PM
    geekhouse23
