help me diagnos the problem...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaxPower, Jun 24, 2013.
  1. Jun 24, 2013 at 9:49 AM
    BamaToy1997
    Bill
    Navarre, FL
    Obviously this is an intermittent problem as you have described it. As such they are the most difficult to diagnose when you bring it to the dealer, or any independent shop. Contrary to popular belief we do not just plug in our scan tool and it tells us exactly what is wrong. Also, not EVERY failure will set a code. A faulty fuel pump is one of those that does not set a code. Faulty fuel filters (dirty/clogged) will not directly set a code, but can cause fuel trim to be too lean, setting a code that way. though that is not a golden rule. Sometimes a dirty filter will simply reduce fuel flow so much that it stalls the engine.
    As for listening to the fuel pump, the 2nd generation Tacoma shows in my system as not having a prime function. That means when you turn on the key, the pump will not engage for a short time period to "prime pressure" the system, so no, you will not hear the pump running when you turn on the key.
    The theft system you mentioned was installed may not have had any problems at all for years, but like any other thing electronic, they can fail at any time. I am not saying that that IS the fault, but it could be, and as such should be investigated first. Since your issue is intermittent this will not be an easy fix, unless you get lucky. lol. Do you have access to a scan tool, ultragauge, or know someone who lives nearby who has one? Engine data at the time of failure is MOST important.
  2. Jun 24, 2013 at 10:24 AM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    check the simple things. clean your battery posts, check ground going to the block. had friend with same problem, his was ground strap to motor. I put a new battery in a van, after 2 months and 1100 mile trip, all of sudden it wouldn't start or even make a sound. first thing I thought of was some one stole my battery, pulled the cables off, cleaned and cranked right up.
  3. Jun 24, 2013 at 11:02 AM
    Steveoc
    Steveoc Follow me....I'm right behind you..
    Steveo
    Milford, Utah
    08' TRD SPORT DC LB 4X4
    TruXport Tonneau cover,removed the charcole air filter, tailgate clamps,fixed the comp/temp,De- badged, De-Flapped, front leveling spacer, aal, K&N filter, blacked out grill,lower bumper, rear bumper, blacked out scoop, Tinted tail lites, tinted fog lites,black sleeved fog cubbies, blk limo tint, blue L.E.D's interior, Under hood L.E.D, rear view mirror lift,blacked out mirrors, Besttop, 20"led bar behind lower grill,
    Sounds like a fuel vapor lock. Fuel lines getting hot?
  4. Jun 24, 2013 at 12:42 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    X2, I'd start here (including a battery load test) regardless of how the terminals look, then temporarily remove the alarm if the issue persists.
  5. Jun 25, 2013 at 6:59 AM
    MaxPower
    MaxPower [OP] Truck Noob
    Cezar
    Connecticut
    09 DCLB Taco TRD Sport
    so, as the truck won't start now, i can't bring it to the place that did the remote start/alarm.
    but yesterday, my fiance's dad came through to trouble shoot. here's what he said...and remember, i'm not car tech savvy: he sprayed ether into the throttle body and it started. he did it twiceand it started both times and stalled when the ether burned away, so he's thinking it's the fuel pump.
    so that's where i stand.
    :confused:
  6. Jun 25, 2013 at 7:04 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    if its fuel pump. dont go OEM. way to expensive. get this http://urdusa.com/Fuel-Upgrades-Fue...uel-Pump/Filter-Upgrade-Kit/product_info.html and also be able to have a external fuel filter. plus its way cheaper.
  7. Jun 25, 2013 at 7:08 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    If it started and ran briefly with ether, then spark is not the problem, nor does it appear air is, so fuel seems like a great place to start. No idea how to troubleshoot an electric fuel pump.
  8. Jun 25, 2013 at 7:10 AM
    MaxPower
    Cezar
    Connecticut
    this may sound stupid, but is there a fuse for an electric fuel pump? if so, is it possible it went and only that needs to be swapped out?
  9. Jun 25, 2013 at 7:38 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    There is a fuse and a relay
  10. Jun 25, 2013 at 7:49 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    There is a fuse, but I doubt a fuse would fail in such a manner. I would say more likely the fuel pump was going out or it is clogged.
  11. Jun 25, 2013 at 8:03 AM
    MaxPower
    Cezar
    Connecticut
    is it common for a fuel pump to go even before 65000 miles?
  12. Jun 25, 2013 at 8:26 AM
    Agent Smith
    It could never happen, or it could happen a few miles from the dealer after you pick it up new. Luck of the draw, or lack of luck.
  13. Jun 25, 2013 at 8:46 AM
    MaxPower
    Cezar
    Connecticut
    i figured that'd be the answer.
    good thing is, if it's the fuel pump/sensor it'll be covered by my warranty. if it's my filter, not so much.
    i just fear that i'll bring it to the dealership and they'll say nothing is wrong...again.
  14. Jun 25, 2013 at 8:46 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    my brother in laws dad had his go out in his at like 80k, so i wouldnt say its not likely at 67k
  15. Jun 25, 2013 at 8:47 AM
    #35
    wrmathis
    Bonaire, GA
    parts and stuff
    the filter is part of the pump. there is no external filter on these trucks. to change the filter, u have to change the pump
  16. Jun 25, 2013 at 8:51 AM
    #36
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Correct, but if the fuse were the issue you'd probably not get it to start at all. That said the fuse could be loose or something.
    I've heard of pumps going in the 60's. Not often, and most of my experience in that has been with people that usually keep the tank low but it is possible sure.
  17. Jun 25, 2013 at 8:54 AM
    #37
    MaxPower
    Cezar
    Connecticut
    i usually fill up at a 1/4 tank. every so often i'll take it until the light goes on, but that is rare of me.
  18. Jun 25, 2013 at 8:55 AM
    #38
    MaxPower
    Cezar
    Connecticut
    the guy i spoke with from my warranty said that the filter would not be covered. so how would they decifer a difference between the filter/pump...?
  19. Jun 25, 2013 at 8:57 AM
    #39
    wrmathis
    Bonaire, GA
    parts and stuff
    got me. but there is not external filter. u can go look all you want
  20. Jun 25, 2013 at 9:11 AM
    #40
    MaxPower
    Cezar
    Connecticut
    well, i'll have the truck towed to the dealership today and they said they'd get to it eventually tomorrow.
    i hate not having my truck.
    sure i can get a rental, but they only cover that cost if something is found to be wrong and under warranty. damn. damn. damn.
