help me diagnos the problem...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaxPower, Jun 24, 2013.
  1. Jun 25, 2013 at 9:14 AM
    #41
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    The fuel pump relay could be sticking.
  2. Jun 25, 2013 at 9:25 AM
    #42
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    Similar problems in a Jeep turned out to be crank position sensor going bad. I replaced both crank and cam sensors to be on the safe side.
  3. Jun 25, 2013 at 9:44 AM
    #43
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Yeah, that wouldn't probably be an issue..I have a buddy who runs his car down to almost nothing. Could just be luck..
  4. Jun 25, 2013 at 9:48 AM
    #44
    MaxPower
    MaxPower [OP] Truck Noob
    Cezar
    Connecticut
    09 DCLB Taco TRD Sport
    a friend of mine mentioned that he replaced the crank position sensor on his sister in-law's Altima last summer when she had a similar problem. no lights on the dash and the Nissan dealership couldn't find anything wrong either beofre he did so.
  5. Jun 25, 2013 at 9:54 AM
    #45
    rleete
    Roger
    Rochester, NY
    Billet grill
    As I understand it, when there is a misfire, the ECU checks the sensors to keep things going smoothly. When it checks and the sensor is going bad, it sometimes gets no/bad reading, which causes the ECU to stumble. Instead of causing possible damage, it just shuts down. The ECU then needs time to reset before starting again. It then queries the sensor again. If the sensor doesn't give a reading upon startup, it won't start and causes the cycle to repeat.
    Also, it wouldn't hurt to change the fuel filter. Even if that's not the problem, it's cheap insurance.
  6. Jun 25, 2013 at 10:02 AM
    #46
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    changing the fuel filter on the second gen is not cheap. its called replacing the fuel pump. which from toyota is like 800 bucks. the filter is in the tank and part of the pump. cant just change it like older vehicles
  7. Jun 25, 2013 at 10:59 AM
    #47
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I think almost all are makes are that way now.
  8. Jun 25, 2013 at 11:03 AM
    #48
    ABA180
    East Bridgewater MA
    I can say that my 2006 Chevy Colorado was the same way. Makes little sense from a cost and ease of service angle, but that's just me.
    Not to hijack but you can also install an external filter on any vehicle. If and when the tank has to come apart just use the aftermarket pump which eliminates the in-tank filter.
  9. Jun 25, 2013 at 11:35 AM
    #49
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Check Coil ignition, Rotor Assy distributor, same situation on 97 ...
  10. Jun 25, 2013 at 4:14 PM
    #50
    netracer61
    netracer61 New Member
    Tommy
    Maryland
    04 Tacoma TRD 4X4 3.4 Auto
    K&N Airfilter
    Look at the connection for the camshaft position sensor and condition of the wiring, sometimes crappy mechanics break it off the timing belt cover instead of removing it correctly. I have seen a few make contact with the belt and cut into it. It would probably be a good idea to pull the timing belt cover off and see if the thin steel plate has a rusty dust covering it, if the rusty dust is present, blow it off with compressed air, remove cam sensor then reinstall. If the plate was rusty as most tend to be, plan on cleaning again and repaint it with a rust conversion paint when your doing the timing belt and water pump. These vehicles have corrosion issues that I have not seen since the chevy vega was being sold. But you probably already know this from the Toyota recalls that you have gotten or soon will receive .
  11. Jun 25, 2013 at 4:26 PM
    #51
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Look to the dealer you had it towed to to fix it. Then tell us.
    Cranks, doesn't start, starts with ether... fuel something not working. What a help.
  12. Jun 26, 2013 at 6:29 AM
    #52
    BamaToy1997
    Bill
    Navarre, FL
    As mentioned, it will start off ether, so ignition is not an issue, also there has not been a distributor on the Tacoma since the early 97 model 4 cylinders.
    There are still other possibilities that can cause no fuel. Yes, most likely you will find a failed fuel pump here, OP, but just because a vehicle will start with ether does not mean it is a fuel pump. Someone mentioned the cam sensor, which is another possibility. A faulty or not-present cam sensor signal will prevent the injectors from firing. While I still agree that the fuel pump is the culprit, I wanted to add more information.
  13. Jul 1, 2013 at 2:04 PM
    #53
    MaxPower
    Cezar
    Connecticut
    service dept at the dealer held on to it for 2 days. said truck started each time, no problems found. one of the service guys drove it for a day, and also found nothing.
    i get the truck back Friday, and yesterday it stalls 2 times, back-to-back, while i was midturn in an intersection. awesome.
    drove it today, no problems.
    i am so frustrated. by the time the problem will be pinpointed, my warranty will be up, haha.
  14. Jul 1, 2013 at 3:40 PM
    #54
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Granted this is an intermittent problem, but after all the trouble you have had the dealership should be looking into this further. Personally I would be opening a claim with Toyota corporate to get this taken care of.
    With the older repair manuals, they use to come with resistance values to test the electrical components of a vehicle. If the part was out of spec then you simply replaced it. I would think that the mechanics have these values in their factory service repair manuals.
    I would tell them to check the fuel pump or open a claim. Its under warranty! Period!
  15. Jul 2, 2013 at 10:10 AM
    #55
    MaxPower
    Cezar
    Connecticut
    i might have to. it's really getting on my nerves that they don't ind anything wrong and their resolution is, "well...i hope it doesn't happen to you while going 70 on the highway or mid-turn in an intersection again."
  16. Jul 2, 2013 at 1:45 PM
    #56
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Pump failure is actually more common than you would think on the 2nd gens. Check XR-Underground, and you'll find lots of issues with them. I would go the route of the URD replacement as suggested. For $165, plus a few hours shop time to install, it's worth the peace of mind, and most likely the cure to the problem you have. Check with Gadget over there (or here), and explain your symptoms.
    The ether test was a great way to prove the issue was with the fuel pump (IMO).
  17. Jul 2, 2013 at 4:48 PM
    #57
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Anyone ever think of hooking fuel pressure gauge up? Fuel pressure is one of the only constants in a EFI system.
  18. Jul 2, 2013 at 5:20 PM
    #58
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    I had similar problem with a Toyota Camry several yrs ago, but more so stalling & sputtering. Went to dealership twice and they couldn't figure it out. Eventually, problem went away on it's own. My guess was a bad batch of gas, I went to an independent gas station and that's when problem started. After a fresh tank of gas & some Chevron Techron additive, never had the problem again.
  19. Jul 2, 2013 at 5:38 PM
    #59
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    What kind of air filter are you using? If you are using one that takes oil (K&N?) then I would clean the MAF.
    Same exact thing happened to my friend. I suggested the MAF and sure enough, the MAF was gunked up.
  20. Sep 25, 2013 at 4:44 PM
    #60
    MaxPower
    Cezar
    Connecticut
    oh...figure i'd update you guys about this batch of fun.
    they held on to the truck for almost 2 weeks. when i was there for maybe the 4th or 5th time, (it had been towed in again), it FINALLY did what i siad it was doing.
    after working on it and testing different leads, they figured it was the fuel pump. they drop the tank, they swap the pump. still no power. they do more digging, follow the fuel line and do/check other stuff (i apologize as this was a few months ago and i am vehicle illiterate) and they call me and tell me that the problem was the brain unti to my remote start/alarm. they claim that it was improperly installed, over 3 years ago, and that the box was pushing some harness that caused the truck to keep shorting and in turn caused the pump to go.
    they take it upon themselves to "fix" the problem. i know the person who put it in, and i know where he put the brain. no way that thing came loose. it was also done through a install place and not some hack job in a drive way of a friends house. i mention this solely because i had, before it was tampered with with out my knowledge, a lifetime warranty attatched to it. had the told me what the issue was before fixing it, i could have had it checked out and would know if it was in fact a valid problem.
    anyhow, i get a call saying that the truck is fixed, and that they are going to be nice and bill the fuel pump repair as a warranty issue, as a favor, because they technically didn't have to do it as it was caused by an aftermarket part. bullshit. bullshit. bullshit. but then they drop the "we will charge you for 6 hours of labor for the remote start rewire/reinstall.
    longer story made long made short: i fucing lost it. had to keep myself from going down there and throwing bricks through their windows and in the end, only paid $150, which i was still against, but they tired charging me over $600.
    and the truck runs well now, and i still want to kill the service manager at the deaership, but i'm happy the truck is fixed.
    sorry for the long read. hope it made sense.
