help me diagnose my clutch problem!! Please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacos Por Vida, Apr 23, 2013.
  1. Apr 23, 2013 at 2:10 PM
    Tacos Por Vida
    Tacos Por Vida [OP] Well-Known Member
    Dominick
    Albuquerque, NM
    97 Taco
    3-inch revtek spacers 265/75 BFG AT Flowmaster exhaust K&N CAI 12'' Type R w/ 1000w amp pioneer cd deck tinted windows
    Ok, so I'm sure there is an existing thread about this but the search system here sucks and my truck is stuck at my friends house and need to try and get it out today.
    Alright now to the problem. My clutch is sticking to the floor and won't release when its engaged. Going to try and bleed the system and hope that works. If not would it be the slave cylinder?? I replaced the master cylinder about 5k miles ago so don't think it's that unless I got a faulty one. I'm hoping it's nothing internal. Thoughts??
    Info: 97 tacoma 5spd 122k miles original clutch
  2. Apr 23, 2013 at 2:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    First and foremost, check the entire system for leaks.
    If you don't find anything and bleeding doesn't work, I would suspect the new Master.
  3. Apr 23, 2013 at 2:22 PM
    Tacos Por Vida
    Dominick
    Albuquerque, NM
    97 Taco
    alright ill check again for leaks. Only thing i saw so far was fluid came out of the master cylinder dust cap. There's a mechanic shop next door and one of the dudes came by and check it out and said to replace my slave cylinder. Should i do that or the master?
  4. Apr 23, 2013 at 2:48 PM
    Dirty Pool
    Dirty Pool HOUSE OF BLUE LIGHTS
    59.4 Miles, 56.67*NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, Both 31" MTZ's and 33" Toyo's, 01 Center console, Map lights, Disraeli gears
    I'm going with steve o 77.
    If a slave cylinder leaks it will leak to the outside world. The master can leak internally and not show, unless an internal leak is producing a geyser inside the reservoir.
    Check the clutch fork for correct position. The Taco fork/pivot ball can get so worn out that they just fall apart.
  5. Apr 23, 2013 at 5:22 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Have you crawled down there to check out the slave cylinder?
    Try to move the lever manually and see if there is any resistance.
  6. Apr 23, 2013 at 5:28 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    It's a bad master. I used auto parts store brand ( a good one, mind you) and on my third one in a year. Sometimes I only got less than 5 k out of one. Save up and get a factory part. Ant the search function works just fine, after my second master went out I looked here and found the same advice I just gave you. Good luck.
  7. Apr 23, 2013 at 7:35 PM
    Tacos Por Vida
    Dominick
    Albuquerque, NM
    97 Taco
    alright so i replaced the slave and same thing was happening. so i replaced the master and now i don't have any pressure in my clutch. the pedal just hits the floor with the slightest pressure applied to it. was only able to bleed it for 5 or so min before i ran out of sunlight. going to bleed it again tomorrow will the pressure come back?? or has something gone wrong internally??
  8. Apr 23, 2013 at 8:06 PM
    Tacos Por Vida
    Dominick
    Albuquerque, NM
    97 Taco
  9. Apr 23, 2013 at 8:10 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    You just need to bleed it longer.
  10. Apr 23, 2013 at 8:13 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    You should have bench bled it, or have somebody step on the peddle while you crack and retighten the brake lines to the master to try and bleed out the air, but you should remove it and bench bleed it to get all the air out.
  11. Apr 23, 2013 at 8:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    more bleeding. Or maybe a broken clutch fork.
  12. Apr 23, 2013 at 8:27 PM
    Tacos Por Vida
    Dominick
    Albuquerque, NM
    97 Taco
    looked up bench bleeding and yeah this is probably what I should do. However currently renting a house with no garage so don't have a bench nor a vice to do this. Only thing i have is some good ole asphalt to lay on. But thanks for the advice guys. Just gonna wake up tomorrow and bleed it again.
