Help me diagnose my steering issue!
Discussion in '1st Gen. Tacomas (1995-2004)' started by AK Taco, Dec 14, 2014.
  1. Dec 14, 2014 at 10:28 AM
    AK Taco
    AK Taco [OP] Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Hey guys, I got back for winter break and my truck is handling like absolute shit. It wanders all over the place, wants to dart from one side to the other, and is to the point where I didn't feel safe driving it.
    I knew I was due for an alignment so I brought it to the shop and of course they called me about an hour later saying they couldn't align it. The shop said both inner tie rods were blown, as well as the driver side LBJ.
    I brought the truck back to my place, jacked it up and tried to see if there was any horizontal play at the wheels... :eek:
    There was a solid 1/4" of play in either direction, and a very audible clunking sound as well. This was on both sides of the truck, and the clunk happens when I push either left or right on the wheels, but it is more prevalent going left.
    What i've done:
    So far I have replaced the inner tie rods, checked the outer tie rods for play, and done the steering column slip yoke tack weld mod.
    EDIT: I have also replaced the rack bushings about 15k miles ago.
    The inners were definitely floppy and in need of replacement, but they did not solve the issue. There was no play in the outers.
    The slip yoke definitely had some play, but even after the tack welds, the clunk was still present as well as the play at the wheels.
    I took a video of the clunk that I'll try to get uploaded shortly, but in the mean time is there anything else it could possibly be besides the rack itself? I feel like I've eliminated the possibilities on either side of the rack and that the only remaining culprit..
    TL;DR
    Terrible handling, loud clunk in steering, what could it be? I've already replaced tie rods and done the steering column tack weld.
  2. Dec 14, 2014 at 10:40 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    is there play in the rack itself?
  3. Dec 14, 2014 at 10:57 AM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    As in the whole rack moving?
    If so, no. The rack itself is not moving at all, I replaced the rack bushings about 15K miles ago.
  4. Dec 14, 2014 at 11:04 AM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    Here's the video.
  5. Dec 14, 2014 at 12:45 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    My guess would be something internally on the steering rack.
    Talk to Dirty Pool. He's very knowledgeable about that stuff...
  6. Dec 14, 2014 at 12:47 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    no i mean the insideof the rack itself. the inside of the rack there are teflon bushings. the main rack rod connects to the inner tie rod. when the bushings wear out this leads to play. pull the boot back and look while moving the tire
  7. Dec 14, 2014 at 1:04 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    cant see what front end parts are moving from that video, you need to show from underneath so we can see the point where movement meets a solid part, that's the failure point.
    wouldn't hurt to check the wheel bearings as well as the other work since it sounds like its time to renew the whole front end.
    also you never mentioned the ball joints were fixed (just that they said one was bad) so replace both upper and lower ball joints because they need replaced if the other parts were worn out plus all 4 only cost $100 combined and take 30 minutes to replace them.
    if the movement you feel is inside the steering rack then that's the detail we need to know. if its moving 1/4" then it should be easy to tell us the exact point where it has movement or even video it. if the movement is inside the rack then you need to replaced the steering rack.
  8. Dec 14, 2014 at 1:21 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    Thanks for the ideas guys. The GF will be over shortly to help get better videos, since it's hard to turn the wheel, move shit so I can see, and take a video.
  9. Dec 14, 2014 at 1:23 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    That 1/4" of movement I mention was how much the tire was shaking each direction. I'll try to get a video of the rack with the boot pulled back to see if there's any visible movement there.
  10. Dec 14, 2014 at 2:10 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    FAT Time for a new rack
    Problem solved..
  11. Dec 14, 2014 at 2:24 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    someone posted about this before I remember. Maybe on the 4R forums. I think the sleeve bushings/guides inside the rack are worn out and need replaced. Believe it's like <$20 and need a 23mm socket or allen. I'll try and find it but can't promise :(
  12. Dec 14, 2014 at 2:31 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    yeah its the bushings inside. After 230k miles its probably more than just the bushings too so i'll just be ordering a new rack. Plus I trust a new rack more than rebuilding an old one myself.
  13. Dec 14, 2014 at 2:47 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  14. Dec 14, 2014 at 3:25 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    common problem like i said. check out rack doctor .com. they install newteflon bushings. most remanufactured racks dont get new ones....
  15. Dec 14, 2014 at 4:12 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
  16. Dec 14, 2014 at 4:26 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Aw shucks:eek:
    You got a whole lot to consider. Hang on till after chow time.
  17. Dec 14, 2014 at 5:01 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Put the new style rack guide in it. There is a reason Toyota changed the design. IMO this upgrade is a must especially for lifted trucks as the tie rod has to operate at an angle post lift install.
  18. Dec 14, 2014 at 5:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    dont know if rack is total issue or not but I'd not drag my feet to changing out the LBJ's mke them a priority
  19. Dec 14, 2014 at 5:28 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    :popcorn:
  20. Dec 14, 2014 at 5:42 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    ooks like a bad steering guide
    I just replaced mine it took away the clunk over bumps.
    New one on the left old on the right
