Help me diagnose my vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wongo, Feb 9, 2012.
  1. Feb 9, 2012 at 11:27 AM
    Wongo
    Wongo [OP] Member
    Wongo
    Ct
    TRD Offroad
    Hi, sorry if this has been asked before but from searching I couldn't find anything similar to my issue.
    I have a 2007 4x4 dbl cab, with bilsteins and an aal. Im also running 285/75 R16's with wheel spacers. I lifted it almost 1.5 years ago, and tires were probably 10 months ago.
    I've had zero issues with my truck, however recently I've slowly gotten a front end vibration at highway speeds. What confuses me is that when the truck leans the vibration goes away. For example while at about 60-65 mph, it's vibrating but if I go through a decent turn on the highway and my taco leans to one side slightly the vibration goes away completely until it levels out again.
    Any Ideas?
  2. Feb 12, 2012 at 10:58 AM
    gpeet
    gpeet Well-Known Member
    if it goes away turning it could be a wheel bearing....but could you better define vibration, where do you feel it?
  3. Feb 12, 2012 at 5:32 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Try this.
  4. Feb 13, 2012 at 3:17 PM
    Wongo
    Wongo [OP] Member
    Wongo
    Ct
    TRD Offroad
    Its a vibration that can be felt and heard in the front end. You can feel it in the wheel and floor.
  5. Feb 13, 2012 at 3:22 PM
    kimo
    kimo Well-Known Member
    Darin
    MONTEREY BAY
    07 TRD sport pre-runner
    If I were you, I'd jack up the front end and wobble the tires to see if there is excessive play, wheel bearing or ? This sounds like something that will only get worse and may cost you more $$$
  6. Feb 19, 2012 at 5:49 PM
    Wongo
    Wongo [OP] Member
    Wongo
    Ct
    TRD Offroad
    Yea finally checked it out today, I'm assuming its a wheel bearing, one front tire had a lot of wobble....
  7. Feb 19, 2012 at 5:52 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    07 with wheel bearing probs already? :confused: unless you have over 150K i wouldnt think it was the bearing. also wheel bearings make a constant road hum noise and get louder when wheel is turned, usually no vibration issues with it though.
  8. Feb 19, 2012 at 7:09 PM
    lopez62566
    lopez62566 Well-Known Member
    Sam Lopez
    Houston,Texas
    05 trd off road prerunner
    None
    Yes ,wheel bearing mine had the same would go away on a turns
