Help me diagnose this front end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Mar 30, 2020.
  1. Mar 30, 2020 at 6:16 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    Symptoms:
    Vibration based noise/growl at speeds above 70 MPH.
    Noise grows with speed.
    Noise cuts away like a light switch below 69/70 MPH.
    Noise goes away as soon as I tap the brakes. Hard to tell if that is speed related or braking related.
    Conditions:
    No transmission shifting is occurring between noise and no noise.
    Noise occurs even with transmission in neutral.
    Noise occurs in 4th (4) and 5th gear (D)
    Noise occurs regardless of RPM.
    Noise does not occur at any RPM unless at 70 MPH or more.
    Noise does not change during turns, as you would expect with a wheel bearing.
    Happens in 2WD or 4WD.
    Happened with and without front drive shaft installed.
    CV axles feel normal when pulling/tugging/pushing on them.
    Wheel bearings feel good when front end is lifted off the ground. No play.
    Brakes don't make any noise at any speed, unless they're the culprit here (I doubt it).
    Suspects:
    Wheel bearing?
    Front differential bearing?
    CV Axle?
    Thoughts?
  2. Mar 30, 2020 at 7:39 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Maybe your tires?
  3. Mar 30, 2020 at 7:41 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Are you running any spacers ?
  4. Mar 31, 2020 at 7:17 AM
    Mxpatriot
    No spacers and same tires have been on the truck for a year without issue.
  5. Mar 31, 2020 at 7:22 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Noise going away as soon as you tap the brakes, points to a brake issue IMO. :notsure:
  6. Mar 31, 2020 at 9:35 AM
    Mxpatriot
  7. Mar 31, 2020 at 9:36 AM
    Mxpatriot
    Yea, I suspect that as well but it's hard to confirm since the fastest I really can get away with going out here is 80 MPH and once I tap the brakes I'm below 70 MPH pretty fast.
    The brakes are also quiet at every other speed/condition.
    Sticking caliper maybe?
    I don't smell any burning smells.
  8. Mar 31, 2020 at 9:54 AM
    SR-71A
    Zack
    Southern Maine
    Larzzzz likes this.
  9. Mar 31, 2020 at 10:11 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Same here. Just wanted to read it out of curiosity.
    SR-71A likes this.
  10. Apr 1, 2020 at 11:24 AM
    Mxpatriot
    I am thinking my next stop is going to be the center carrier bearing on the driveshaft. Wish me luck.
  11. Apr 1, 2020 at 11:31 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Carrier bearing or driveshaft u-joints maybe?
  12. Apr 1, 2020 at 11:47 AM
    SR-71A
    Zack
    Southern Maine
    Any vibrations in the truck? Given its an 06 your CB is probably sagging pretty bad, but seems that vibrations are usually a symptom of that and not noise
  13. Apr 1, 2020 at 3:16 PM
    Mxpatriot
    U-joints are all tight. Replaced one on the front driveshaft that a tiny bit of play in it, even though it wasn't the cause of the noise (removed front driveshaft and tested, noise still there).
    CB has a little bit of play in it. Ordered a new one that will arrive on Sunday to see if that is it before I move on to more expensive things like wheel bearings and CV axles.
  14. Apr 1, 2020 at 3:17 PM
    SR-71A
    Zack
    Southern Maine
    You could also pull the rear drive shaft and go for a spin in 4Hi. That would certainly rule a few things out
  15. Apr 1, 2020 at 3:17 PM
    Mxpatriot
    LT front and rear on an '06 with a hard 210k on the odometer, she vibrates occassionally lol.
    The noise is accompanied by minor vibrations and is a vibration type noise/hum if that makes sense.
    CB has been replaced several times over the life of the truck. Going to do it again just to see if that's it, got an open box special Dorman unit off Amazon for $35.
    SR-71A[QUOTED] likes this.
  16. Apr 1, 2020 at 4:21 PM
    Mxpatriot
    That's a good point, but at $35 for the CB, I'm just going to replace it when I drop the driveshaft anyways and see if that does it.
  17. Apr 1, 2020 at 4:41 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'd be very tempted to try a different manufacturer Carrier Bearing given how many you've gone through. Dorman is not noted for extremely high quality (or long lasting) parts.
  18. Apr 1, 2020 at 4:46 PM
    Mxpatriot
    I can't disagree with that.
    I figured since this is a stab in the dark, I'll go with the cheaper unit this time.
  19. Apr 1, 2020 at 11:32 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Maybe your clamshell bushing? :notsure:
  20. Apr 3, 2020 at 8:36 PM
    Mxpatriot
    No change to noise when 4wd is switched on, which I think rules that out. Also already have an ECGS bushing in there.
