Help me diagnose this front end noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Mar 30, 2020.
  1. Apr 5, 2020 at 4:36 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    So I changed out the CB - no change.
    Also found that the U joint at the driveshaft coming out of the transfer case was toast, even though when I grabbed and twisted the driveshaft on the truck, I couldn't detect play in. Off the truck it had all sorts of play in it.
    Also did not correct the noise I'm hearing.
    F'ing truck...
    SR-71A likes this.
  2. Apr 8, 2020 at 6:08 AM
    Mxpatriot
    Solved.
    Was the front driver side wheel bearing. Displayed no symptoms below 70 mph and could not feel the grinding in it until the bearing was off the truck.
  3. Apr 8, 2020 at 8:23 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Glad you finally slayed the dragon! Dare I ask what brand of bearing you put in? It makes a bigger difference than many people believe.
  4. Apr 8, 2020 at 12:18 PM
    Mxpatriot
    Carquest.
    (for shame, I know).
    3 year warranty and was in stock at my local advance auto for $150 after a 20% discount code. We'll see how it does. If it burns out, it's under warranty and I can swap those things in under 40 minutes.
  5. Apr 8, 2020 at 2:23 PM
    REB55
    REB55 Well-Known Member
    SE LA
    2011 SR5 Prerunner Access Cab
    Sold POS 2016 SR5 DCSB
    What made you pull the bearing off the truck? Did you decide to just start changing parts?
  6. Apr 9, 2020 at 10:06 AM
    Mxpatriot
    Pretty much. After replacing the carrier bearing and the toasted U-joint, without improvement on the noise, I knew it was going to be something in the wheel bearing / cv axle / front differential world. Wheel bearing was the easiest one to do. Figured that if it didn't fix it, I would just pull the new bearing off and hold onto it as a spare/eventual replacement.
  7. Sep 5, 2020 at 4:00 PM
    Paulrv6
    Paulrv6 Well-Known Member
    paul
    2005 Tacoma
    Can I ask you if the bearing was all one piece or did you have to press the old hub into the new brg? I saw a video where the guy had to press out the old brg from hub. I'm not sure what year he was working on either. Mine is an 05 so I wondering if it is the same. Thanks
    paul
