help me find a hot wire!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Broseph Stalin, Nov 4, 2014.
  1. Nov 4, 2014 at 10:53 AM
    Broseph Stalin
    Broseph Stalin [OP] Well-Known Member
    Justin
    Santa Barbara
    '10 white dbl cab LB trd sport
    15% tint , Bak Flip G2 tonneau cover, poplock WeatherTech mats, FX-R retrofit, BHLM, eyelids, smoke Lamin-X, daystar leveling kit, studded snow tires and a shitload of sand bags
    I installed a 2 gallon air compressor in the bed of my truck, grounded it to the bed bolts but am having difficulty finding a strong enough hot wire to splice into that is ONLY ON when the motor is on, NOT accessory power.
    I tied it into one of my daytime running lights and it ran for about 10 seconds before shutting off the compressor and flipping off that individual light. ONce i turn the ignition off and restart it the light re-illuminates but the same thing happens again. Its basically not a strong enough wire to pull off of...HELP PLEASE!
  2. Nov 4, 2014 at 10:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You need to use a relay. Pickup a basic automotive relay at your local auto parts store, they're only a few bucks. The relay will have 4 prongs, 30, 85, 86 and 87. The wire you tapped from your daytime running light, run that wire to pin #85 and ground pin #86. Run a power wire from your battery with an in-line fuse to pin #30, then connect the compressor to pin #87. That way, the compressor power in will come from pin #87 but will only be 'hot' when the DTRL are on.
    What you did was not good for your electrical system. You should NEVER add to an existing circuit, just asking for trouble and/or electrical failures.
  3. Nov 4, 2014 at 11:05 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Doesn't the plug in trailer hitch lights do the same thing? Since they plug into your existing brake lights. Don't know, just asking.
  4. Nov 4, 2014 at 11:08 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    X2.
    And especially on that last part.
  5. Nov 4, 2014 at 11:18 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Yup, relay it. If you run too much power on a different circuit you will keep popping the fuse, and if you add a bigger one you could start a fire.
  6. Nov 4, 2014 at 11:29 AM
    Broseph Stalin
    Justin
    Santa Barbara
    so if i understand correctly i will be adding a wire to my DTRL's and it will end in #85 and then i run a wire from #86 to a ground? do i still need the ground connected that is coming off the compressor? also what gauge wire is appropriate for these 2 spare wires?
    thankyou for your help
  7. Nov 4, 2014 at 1:53 PM
    Iggy
    Northern CA
    Check out the build
    This is almost the same, just wire up 87 to the compressor, and 86 to a switch or straight to accessory power.
    When the truck has power to accessory it powers up 86 which switches 87 on straight from the battery. When there is no power at 86 the compressor loses power as well.
