Help me find a knock/grinding noise.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upTOPOverland_Drew, Mar 28, 2019.
  1. Mar 28, 2019 at 8:03 AM
    upTOPOverland_Drew
    upTOPOverland_Drew [OP] upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Hey Guys,
    2017 TRDOR with 45k on it and some decently hard wheeling. I get a pretty bad grinding/popping noise during change of direction i.e. during turns and such. I can even feel it in my left foot....body mount bushing is my first thought?
    What do you think?
  2. Mar 28, 2019 at 8:56 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I had loose skids (tight but loose enough) where it would pop under turning conditions due to the frame flex. The description could be a high possibility of body mount replacement required.
  3. Mar 28, 2019 at 8:57 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    First place I would look. However . . . "some decently hard wheeling" may have broken something suspension wise.
    Check the cab mount and let us know what you figure out.
    G.
  4. Mar 28, 2019 at 8:57 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    check your cv axles
  5. Mar 28, 2019 at 6:05 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    CVs appear to be okay, no tears in boot or anything.
  6. Mar 28, 2019 at 6:06 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I've been looking but its a little hard to tell. I'm throwing the truck on a lift tomorrow
  7. Mar 28, 2019 at 6:06 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    interesting, ill look at that
  8. Mar 28, 2019 at 6:07 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    axles can go bad and the boots will look fine and not have any leaks.. Popping on turns sounds like cv.
  9. Mar 28, 2019 at 6:08 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    It’s your front radiator support bushings for sure 99%.
  10. Mar 28, 2019 at 6:13 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    It doesn't pop unless I make harder turns that cause body roll. Slow or smooth turns, are silent
  11. Mar 28, 2019 at 6:13 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    negative, done did replace those already.....
    Jason TRD OR[QUOTED] likes this.
  12. Mar 28, 2019 at 6:22 PM
    Jason TRD OR
    Check your cams
  13. Mar 28, 2019 at 8:32 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I retourqued all my body mounts and radiator mounts this evening...we'll see tomorrow
  14. Mar 28, 2019 at 8:34 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Are you lifted? My coils hit my swaybar sometimes making a knocking sound and I had to get a spacer kit for it
  15. Mar 28, 2019 at 9:42 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I am but this is recent. I still check bc i thought the same thing but no dice
  16. Mar 28, 2019 at 9:43 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    it obnoxious bc i know what to look for but all of the stuff that is even remotely obvious seems good
  17. Mar 29, 2019 at 4:20 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    SURPRISE!!! a failing steering rack!
  18. Mar 29, 2019 at 4:31 PM
    Garyji
    Gary
    On a pretty new truck? WTF have you really been doing to it? Too new for that failure unless you’re beating the shit out of it.
    . . . and now we get the truth. . .
    G.
  19. Mar 29, 2019 at 4:40 PM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    My brother had a similar issue after hard wheeling and his power steering went out shortly after
  20. Mar 29, 2019 at 6:13 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    You already got the truth...I wheel it decently hard as said in first post and if you look at my build you'll see I'm far from stock. I'm NOT gonna try any of the warranty BS like every other asshat on here tries. You gotta pay to play and pushing 34s around Colorado and Utah ain't easy. It's my doing so I'll put something stronger in there next
    Sincerely,
    not a stock mobber :thumbsup:
    Freegolf and Garyji[QUOTED] like this.
