Help me find a UJoint!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 3rYODA, Sep 23, 2017.
  1. Sep 23, 2017 at 11:15 AM
    #41
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I replaced all four of mine on my 95.5 about 2 year ago, about, all Toyota parts. I usually have all my receipts if you want me to check when i get home, it'll be tomorrow though. I'm thinking i got them from camelbacktoyota.
    There's one guy you can call that i always used for parts in the past until his owner made him quit taking credit cards. He now takes PayPal. The best guy i found for oem parts, his name is gary Smith, parts manager for Newnan Toyota, Georgia, man is sharp with oem parts, and he use to be the cheapest. Try this number, it might be it 770 502 1333.
  2. Sep 23, 2017 at 11:27 AM
    #42
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The driveline shops that I spoke to had a turn around time of one or two days. It's pricey, but they have parts that can replace the D.C. joints and get your driveshaft ready to go in a day or two. I only contacted two driveline shops down in OC though. Not sure who could do it up in your neck of the woods.
    I bought a spare driveshaft when I found out my D.C. joint was going for less than it would have cost to rebuild it. I'd go that route. You can tell if the joints are going to be an issue (at least for the moment) by wiggling them and checking for play and making sure they go smoothly through the full range of motion. That will at least sort you out for the time being. There are a few dismantlers that could probably get you one by tomorrow or Monday.
    I'm into mine about $300 and it still needs a new carrier bearing (I'm replacing it with a solid one when it goes on the truck) so I'm not sure it would be any cheaper to get it from me since you'd be looking at $450 after you replaced the cb.
  3. Sep 23, 2017 at 1:53 PM
    #43
    3rYODA
    3rYODA [OP] Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    I want to have a custom drive shaft made, hopefully a one piece, two joints are bad and it took me a whole day to get one out
    No ones open till Monday I'm fucked
    So to all who own a first gen Toyota
    SELL THE FUCKEN THING BEFORE ITS A PAPERWEIGHT NO ONE WANTS
  4. Sep 23, 2017 at 2:00 PM
    #44
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    There's probably a bus system that gets to where you need to go - or close at least. What do you do for work? If it's mobile, then yeah that's tough to get around, but if you just go from a to b then a good extra 4 hours a day will at least save you uber costs. Tough predicament to be in though.
    DustStorm4x4 likes this.
  5. Sep 23, 2017 at 2:27 PM
    #45
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    I work in the movie industry, so yeah one day I could be 10 mins from work or I could be 4 hours away from home and need to be there within 5 hours of being called, I've mostly been doing splits and working afternoons and getting off at 3-4am so I'd be stuck and we all know how much uber loves the 4am rides ,
    Plus I live somewhere fairly secluded so it's not the easiest to get uber or a buss around here I could find one to get me an uber sure but still a good half hour walk to find one, I defenetly am getting rid of my Tacoma and buying somthing different asap
    Fucken dumbfounded me that these can't be replaced and NO ONE STOCKS THE CORECT JOINT I mean how the fuck dose that happen I don't know how a driveshaft shop could replace it unless they altered the caps and rings they have then it's just a matter of time till the next piece of crap falls off
    EVERYONE NEEDS TO GET RID OF THERE FIRST GEN TACOMA
  6. Sep 23, 2017 at 3:53 PM
    #46
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Piss poor planning makes for piss poor performance .Mom always told me
    It must be really rough not having any friends to borrow a vehicle from .
    That is why I have 4 street legal vehicles my repairs tend to go sideways all to often
  7. Sep 23, 2017 at 3:57 PM
    #47
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think this one might have snuck up on him. Renting a car may be cheaper than uber if that's really going to run you $1k a week...
  8. Sep 23, 2017 at 4:01 PM
    #48
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    They can be replaced, they are available and if you know how it's not hard. Takes me about an hour. In your case go back to post #37.
    And a 1 piece shaft is a downgrade.
  9. Sep 24, 2017 at 1:09 AM
    #49
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Time for a 3rd gen...
  10. Sep 24, 2017 at 2:43 AM
    #50
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    221BDA79-86CF-4040-ADDF-B6D067144095-3806-000004EE572E8E6A.png Just what are these dimension of your u-joint?
  11. Sep 24, 2017 at 7:09 AM
    #51
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    A double carden joint is a bitch to rebuild
    Normally its a repalce the joint. Which os 2 ujoints and a ball socket. It's not something i think you want to try and tackle yourself. Take it to a driveline shop or get a used drive shaft. I could get you a used shaft and send by Wednesday. But would probably cost $200.
  12. Sep 24, 2017 at 7:23 AM
    #52
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Just what are these dimension of your u-joint?[/QUOTE]
    id need to get my tools from work to get the dimensions, but you know those are for a second gen by the snap rings, the rings themself are going to be very thin
    Wouldent be a bad idea my slip yoke has been sheered a bit, but how are the joints going to be, I'm wondering if it'd be worth it to have a custom shaft made with new joints but I got no idea if that's possible, if I gave my driveshaft to the shop I'd imagine they'd have the same problem finding a UJoint thatd work
  13. Sep 24, 2017 at 7:24 AM
    #53
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    More like time for a diesel
  14. Sep 24, 2017 at 7:25 AM
    #54
    mechanicjon
    Jon
    Scottsdale Arizona
    Wouldent be a bad idea my slip yoke has been sheered a bit, but how are the joints going to be, I'm wondering if it'd be worth it to have a custom shaft made with new joints but I got no idea if that's possible, if I gave my driveshaft to the shop I'd imagine they'd have the same problem finding a UJoint thatd work[/QUOTE]
    Driveline shop will weld a new joint assembly on it.
    3rYODA[QUOTED][OP] likes this.
  15. Sep 24, 2017 at 7:26 AM
    #55
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Gary is out on vacation till wendsday and will then be gone till Monday bummer
  16. Sep 24, 2017 at 10:30 AM
    #56
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    www.car-part.com came up with a couple in SoCal for 1998. You might be able to find one close to you if you search through the model years and make some calls to places that have them that could ship them.
  17. Sep 24, 2017 at 10:47 AM
    #57
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Not sure of your location, but this guy rebuilt my dc joint after another shop fucked it up.
    He's in Lomita, CA:
    Drive Shaft Masters Co
    25828 President Ave, Harbor City, CA 90710
    (310) 539-1900
    https://goo.gl/maps/BbFr97pwrfA2
    DustStorm4x4 and Dalandser like this.
  18. Sep 24, 2017 at 10:49 AM
    #58
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How much did he charge just for an idea of what I might be looking at if I take my blown up one over there?
  19. Sep 24, 2017 at 11:01 AM
    #59
    quetzal
    Mario
    Long Beach, CA
    @Dalandser
    I don't remember but it was total worth it. Give him a call.
    Dalandser likes this.
  20. Sep 24, 2017 at 11:09 AM
    #60
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Will do.
