Help me find a UJoint!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 3rYODA, Sep 23, 2017.
  1. Sep 24, 2017 at 1:01 PM
    #61
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    If you absolutely need a car while you're fixing your truck you can buy a used crown Vic at a police auction for under $1,000. I had a buddy who drove one while his car was being fixed.
    Hell I've seen some cars on Craigslist that run for under 1,000
    DustStorm4x4 likes this.
  2. Sep 24, 2017 at 1:06 PM
    #62
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Just ditch the taco for the $1k crown vic and call it done: https://m.youtube.com/watch?v=vHvXi_HejnI
  3. Sep 24, 2017 at 4:19 PM
    #63
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I guess I could ditch the AC/DC and start listening to "Hayseed Dixie" instead while I'm at it...
    Stocklocker[QUOTED] likes this.
  4. Sep 24, 2017 at 10:50 PM
    #64
    RangeDrive
    RangeDrive Well-Known Member
    02 V6 Double cab
    Icon front end, OME Dakar rear, ARB front bar
    Don't know if you found one or not but I just went through this. The 2 ujoints in the center of your 2 piece drive shaft are located in the double cardon joint. after exhausting every option I found one manufacture that made the correct size for our trucks. The following is a excerpt from the thread I made when I was trying to find the Ujoints.
    "Ok just to update this thread, I sourced the required u joints from Rockford. All other options were either out of business or the suppliers no longer satires them. The part you need for the double Cardon joint in the 2 piece driveshaft is part number K2540. I called Rockford directly and their customer service was very helpful and kind, I thanked them for still making this u joint and made sure they knew they were the only manufacturer I had found that had them still. Thank God for them, because they were my last straw. Hope this helps anyone in the future with my problem."
    Hope this helps!
  5. Sep 24, 2017 at 10:56 PM
    #65
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Was it both joints and the center ball? How much $$?
  6. Sep 24, 2017 at 10:57 PM
    #66
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @Dirty Pool ?
  7. Sep 24, 2017 at 10:59 PM
    #67
    mechanicjon
    Jon
    Scottsdale Arizona
    Might need to horde me about 20 rebuild sets....:D:D:cool::rolleyes::evil:
    DustStorm4x4 and Dalandser like this.
  8. Sep 24, 2017 at 11:14 PM
    #68
    RangeDrive
    02 V6 Double cab
    No just the joints, my centering ball was good.. if I can recal I got 3 and I want to say they were less the $15 a piece but please don't hold me to that
    cruiserguy and mechanicjon like this.
  9. Sep 25, 2017 at 8:19 AM
    #69
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The "Rockford 2540" is the only known replacement joint for the "at some point" after 99 DC joints with the outside clips and they know it. There is no clear point after 99 when Toyota switched.
    There are currently 4 manufacturers of joints for the larger, earlier, inside clip style. They span the whole spectrum of quality/price. 2 from USA, one each from China and Japan. Toyota does not sell any 1st gen DC joints or either of the 2 sizes of center ball kits period.
    The problem folks have finding the earlier style is that no manufacturer lists them as a 1st gen Tacoma application. You must first go by dimensions, then you find the applications, then the vendors.
    Dalandser[QUOTED] likes this.
  10. Sep 25, 2017 at 8:53 AM
    #70
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I had these guys rebuild my driveshaft in my 2000 PreRunner. They also sell parts.
    https://www.powertrainindustries.com/about.htm
  11. Oct 28, 2017 at 8:33 AM
    #71
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    Hey Dirty Pool, can you provide part numbers and vendors for the pre-99 ujoints?
    Thanks
    Jeff
    Dalandser likes this.
