Help me find where this is coming from
Discussion in '2nd Gen. Tacomas (2005-2015)' started by T-Rex266, Jan 30, 2012.
  1. Jan 30, 2012 at 5:34 PM
    T-Rex266
    T-Rex266 [OP] T-Rex Moderator
    At first I thought it was a lose d-ring as one of them was looser compared to others so, I removed it hoping that would solve this annoying problem. Nope, no bueno :( this rattling is driving me nuts while driving. Anybody have any ideas where it's coming from?
    http://www.youtube.com/watch?v=8grGR5MpVrA
  2. Jan 30, 2012 at 5:42 PM
    XPOTRPR
    XPOTRPR @ADDoffroad
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    CHECK BUILD
    Hmmm.. your shaking the bed right? Is It only when you do it from that side or does It happen from anywhere? Could be a bed bolt to the frame. Or to that one fender.
  3. Jan 30, 2012 at 5:47 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    DAMN! That is loud and very annoying!! i would have to agree with ^^ sounds like the bed is loose? Maybe a loose mounting bolt on the top of your shock? Does it come from both sides? it looks like your shaking the bed side to side, does it make the noise when you jump up and down on it?
  4. Jan 30, 2012 at 5:52 PM
    T-Rex266
    Not sure. I've only tried it from that side.
  5. Jan 30, 2012 at 6:01 PM
    T-Rex266
  6. Jan 30, 2012 at 6:09 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    Sean is there any chance that the tracks for your bed rail system are loose?
  7. Jan 30, 2012 at 6:15 PM
    T-Rex266
    The tie downs or the tracks? Tie downs, no. How can I check the rails?
  8. Jan 30, 2012 at 7:34 PM
    squad314
    Marc
    If you look inside the rails that the D rings slide back and forth on you will see a series of Torx head screws which secure the rails to the composite bed. Check those for tightness.
  9. Jan 31, 2012 at 6:58 AM
    T-Rex266
    It's coming from the bed somewhere
  10. Jan 31, 2012 at 8:45 AM
    squad314
    Marc
    Not something in the cubby compartments?
  11. Jan 31, 2012 at 8:47 AM
    T-Rex266
    I'll check again but I doubt it. The noise is closer to the cab of the Taco
  12. Jan 31, 2012 at 8:51 AM
    squad314
    Marc
    Sorry for the useless suggestions Sean, just love to see you find it. Squeaks and rattles drive me crazy!
  13. Jan 31, 2012 at 9:12 AM
    T-Rex266
    No worries man. Any and all suggestions are welcome. Ya it's driving me insane.
  14. Jan 31, 2012 at 10:05 AM
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    Try it with the taligate down?
  15. Jan 31, 2012 at 10:22 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    If the bed seems secure, Check everything "attached to the bed" - ie bed compartments, I see you have a TRD, so check the power assy. unit mounted to where the passenger bed compartment would be, spare tire below might be shifting as you shake, bed rails as mentioned, bed toprail caps, fenders/fender flares/supports, etc., etc.. Might need a buddy to shake while you inspect... Good luck let us know if you figure it out...
  16. Jan 31, 2012 at 10:27 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Also, there is/was an issue with some having the "metal bed supports" in the rear by the tailgate area crack and separate between the metal and composite material. This could make some noise, just check the area for stress cracks to see if anything pops out...
  17. Jan 31, 2012 at 12:16 PM
    T-Rex266
    Yup. Still there, although not as frequent/loud
  18. Jan 31, 2012 at 12:18 PM
    T-Rex266
    No spare but the bolt that would normally secure a spare may be loose?
    Cool, I'll ck what you suggested when I can.
  19. Jan 31, 2012 at 3:22 PM
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Spare tire hoist cable and tire attachment!!!!!
  20. Jan 31, 2012 at 3:27 PM
    T-Rex266
    U sure B?
