Help me find where this noise is coming from
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zth25, Jun 22, 2016.
  1. Jun 22, 2016 at 3:15 PM
    zth25
    zth25 [OP] Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Last Friday I got my truck back from its Frame replacement for the recall. Saturday I put my new lift on. The truck seemed fine when I got it back. All in all I did OME 887 coils, JBA upper control arms, .25" spacer on drivers side, ditched the sway bar, and progressive 1.5" aal in the rear. The truck has 5100s all the way around. I also did front pads and rotors during the install.
    About a day after I put the truck back together I noticed a metallic clicking sound. I notice it at low speeds under 20-25mph, it happens when I hit pot holes or bumps, and also when I hit the brakes, but not every time I hit the brakes. The sound is present in both 2 and 4 wheel drive no diffrence
    Things I've checked:
    -hubcaps and lugnuts
    -front bumper crash bar bolts
    -front skidplate
    -didn't seem to be any wiggle in the pads
    -no play when I Jack the truck up and shake the wheel
    -lca bolts
    -3 coilover top nuts
    -caliper bolts
    -grabbed and shook damn near everything I can get my hands on.
    -exhaust hangers
    -if I drag the brakes when I drive it makes no diffrence, still get the sound when I hit bumps.
    I've laid under my truck and looked at everything for a total of about 2 hours. I'm stumped. Truck drives fine, I do still need to get an alignment however.
    One thing I noticed is some play where the cv axle goes into the differential. I can wiggle it up and down and it has some play in and out of the diff. It is not a lot of play at all, and I've heard some is normal.
    Plz help
  2. Jun 22, 2016 at 3:18 PM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    So it doesn't do it at higher speeds?
  3. Jun 22, 2016 at 3:19 PM
    zth25
    Zach
    It's does not. I hit the biggest pot hole in can find doing 35+ and I can not hear it at all.
  4. Jun 22, 2016 at 3:27 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Idk it sounds like the brakes to me.
  5. Jun 22, 2016 at 3:28 PM
    zth25
    Zach
    I'm gonna try to get a video on my phone tonight but Idk how well it will work
  6. Jun 22, 2016 at 4:22 PM
    zth25
    Zach
  7. Jun 22, 2016 at 4:31 PM
    zth25
    Zach
    Also dragging the brakes makes not diffrence. I think that rules out the pad wiggling theory
  8. Jun 22, 2016 at 4:43 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    That video sounds like the noise my exhaust made everytime I hit a pot hole after I replaced it with the TuRD catback.
    If it is that you can replicate it by trying to wiggle/rocking the exhaust by pushing on the exhaust tip with your feet.
  9. Jun 22, 2016 at 4:46 PM
    zth25
    Zach
    No luck with this, thanks though
  10. Jun 22, 2016 at 4:48 PM
    epa4wd
    Eduardo
    2019 SR
    No problem,
    I saw the video again, it sounded exaclty like that.
    In the 2nd video the noise you are reffering to is at 19-20s of the video?
    If so, again exaclty as mine did.
    Noise was produced from the flange, between the cats and muffler.
  11. Jun 22, 2016 at 4:50 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    I don't know your exhaust setup, but any chance it could be the muffler heat shield ? I had a buzzing kinda noise on a Ford Truck I owned years ago, and that's what it was .... I had it tack welded back on and problem solved ....
    just a thought
  12. Jun 22, 2016 at 4:52 PM
    Yoda's TRD
    David
    Haslett, MI
    whoops, someone is typing faster than me
    LOL
  13. Jun 22, 2016 at 5:24 PM
    zth25
    Zach
    Yea that's the sound I was talking about. You can really hear it in the first video. I'll give the exhaust a thorough check
  14. Jun 22, 2016 at 5:38 PM
    epa4wd
    Eduardo
    2019 SR
    Where the flange is, check the bolts, not sure how to explain it but I'll give it a try; in the flange from the muffler side, the screws should be centered inside the screw hole, if the exhaust is not perfectly aligned, then screw is not centered in the hole and when the exhaust moves the screws make contact with the flange causing noise. A picture would help but I'm not able to take one right now.
    In my case I ended up replacinrg the flange bolts and screws, gasket and using a shorter hanger ( last one closer
    to the exhaust tip) to rotate the exhaust counter clock wise slightly if looking at the truck from the back.
  15. Jun 22, 2016 at 5:51 PM
    zth25
    Zach
    I just gave it a quick shake and it seemed solid. It appears the dealer put new bolts Inot when they did the frame swap. I'll have to give it a better look though
  16. Jun 23, 2016 at 4:05 PM
    zth25
    Zach
    So I think I may have found the source. When I installed my jba UCA's I left out the metallic spacer they come with. For some reason I thought you only needed that if you got new spindles and it was supposed to press in the spindle. Well I was wrong. The spacer is supposed to sit on top of the spindle underneath the ball joint. My theory is that beacuse this spacer is not there the ball joint is able to move up and down and smack into the spindle and produce the sound.
    I really hope this is it cause if it's not and I can't find this noise I'm gonna want to set the damn thing on fire.
  17. Jun 24, 2016 at 6:41 PM
    zth25
    Zach
    Well the spacer did not fix the noise. May have made it a bit quiter or I'm just imagining things.
    Gonna get a go pro mounted underneath tommorow
  18. Jun 26, 2016 at 7:10 PM
    zth25
    Zach
    The noise is coming from the front bumper crash bar. I removed it and wellah no noise. Luckily I have a spare crash bar. Gonna put that on and hopefully it will make a diffrence.
  19. Jun 28, 2016 at 4:35 PM
    zth25
    Zach
    Replaced the crash bar, no more noise.
