Help me Identify this brush guard...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Leadgolem, Oct 25, 2010.
  1. Oct 25, 2010 at 3:14 PM
    Leadgolem
    Leadgolem [OP] Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I found a brushguard on craigslist for cheap. No mounting brackets though. I want to identify it so I can see if I can order the brackets.
    I held it up with the headlight guards in place, and it's exactly the right size. No guarantee that it's actually for a tacoma though. The only markings on it are, made in mexico, and 08526060.
  2. Oct 25, 2010 at 5:36 PM
    Leadgolem
    Greg
    Littleton, CO
    Anybody?
  3. Oct 25, 2010 at 6:39 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    hmmm....mall crawler?
    Paint that stuff black!!!
  4. Oct 25, 2010 at 6:58 PM
    willtotheumm
    willtotheumm Yo Taco!
    Will
    Santa Maria, CA
    03 Lunar Mist DC TRD Offroad PreRunner V6
    K&N intake. That is all. For now...
    Looks like one for a Ford Explorer to me.
  5. Oct 25, 2010 at 7:00 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    looks like the style jcwhitney sells. dont know the brand...
  6. Oct 25, 2010 at 7:41 PM
    Leadgolem
    Greg
    Littleton, CO
    I'm going to bed line it before I mount it. For the price I got I wasn't going to quibble on finish. :)
    Yep, looks like it to me too. Go industries pro series.
    Probably from an f250 or f350. On close inspection I can feel where the bracket that actually mounts this thing on the ford has been cut off. You can see where it goes into the slot in the bumper in the top pic, as well as the holes for the headlight guards. I'm pulling the horizontal bars off now to see if they have been cut down as well.
    This is going to be a bit tricky to mount....
    EDIT: Forget pulling the horizontal bars off. I don't have a hex key large enough.
  7. Oct 25, 2010 at 7:45 PM
    Yoytoda
    Roland
    completely stock
    how wide is it?
    it would be easy to weld up some brackets
  8. Oct 25, 2010 at 8:02 PM
    Leadgolem
    Greg
    Littleton, CO
    27 3/4" inside the vertical plates. The plates are 3/8" steel. Reasonably sure this is stainless, based on the go industries product info.
  9. Oct 25, 2010 at 9:06 PM
    Leadgolem
    Greg
    Littleton, CO
    I'm thinking 3/8" plate steel for the mounts. Bolted to the inside of the frame. I'll have to drill holes and install sleeves for the bolts. The brackets would need to curve outward and up to meet the bottom of the guard. Then More drilling and bolts to connect the guard to the brackets. I need to measure and see how far it is between the inside of the frame rails though. Probably need to use a sledge and bend the brackets slightly so they would fit.
    Other thoughts on mounting would be welcome. :)
  10. Oct 25, 2010 at 9:12 PM
    Yoytoda
    Roland
    completely stock
    id have to see it. 3/8" would be a bit overkill. 1/4" would probably be plenty.
  11. Oct 25, 2010 at 10:11 PM
    Leadgolem
    Greg
    Littleton, CO
    The vertical plates on this thing are 3/8", so I figured I'd match them. :)
  12. Oct 25, 2010 at 10:12 PM
    Yoytoda
    Roland
    completely stock
    oh then go for it...
  13. Oct 26, 2010 at 7:57 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    highly doubt that's stainless...would cost ALOT if it was
    probably just chromed
  14. Oct 26, 2010 at 7:59 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^^That^^ It's just a chrome plate.
  15. Oct 26, 2010 at 8:16 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Looks like a Westin pushbar with optional brush guards.
