Help me identify this noise, please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by needataco, Oct 24, 2016.
  1. Oct 24, 2016 at 3:38 PM
    needataco
    needataco [OP] Well-Known Member
    I have a noise that I can't identify. 08 Access Cab, manual transmission, 2.7l 4cyl. There is a metallic "rattle" that appears to be coming from underneath the truck. It mainly is noticeable when the engine is under load and in gear at about 1600rpm, though I've also been able to reproduce it at higher rpms during downshifting. I can't get it to make the sound at all when in neutral. I found and fixed a loose heat shield thinking that was the cause, but it didn't help at all. I have a feeling that the noise is coming from a catalytic converter, but that's just a guess. Does anyone have an idea what this might be?
    Here is a video (you might have to turn up the volume a bit to hear it over the road noise):
    https://youtu.be/JT1lm52-JVQ
    Thanks!
  2. Oct 24, 2016 at 3:49 PM
    CHarrison32
    CHarrison32 Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
    Possibly the heat shield/clam shell shield on the catalytic converter. My rivots or what ever is holding the head shield together rusted out and it began to rattle.
  3. Oct 24, 2016 at 3:50 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I don't hear anything except white noise.
    That said, I'd be more inclined to think your catalytic converter is failing. 2.7 cats just got recalled, not sure your truck applies.. but I've gone through 3 (and my truck is a 2013)..
    needataco[OP] likes this.
  4. Oct 24, 2016 at 3:56 PM
    CHarrison32
    Cody
    West Virginia
    2011 AC 4x4
    I agree. I didn't watch it before I answered. But I did have a rattle noise and mine was the heat shield. Just my 2 cents
  5. Oct 24, 2016 at 3:59 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Halfway through video you can just hear it. Like others said most likely the heat shield attached to the cab floor underneath or the actual clam shell shield that goes around the catalytic convertor.
  6. Oct 24, 2016 at 7:51 PM
    needataco
    Thanks for confirming, it is hard to hear but if you turn up the sound you can hear it right about at the halfway point. The cab floor heat shield was loose (this was the heat shield I mentioned in my original post) but it's all tightened up now and didn't change the noise at all. As far as I can tell the shield on the catalytic converter is nice and tight as well. Is there any way to confirm that either of these are the source?
  7. Oct 24, 2016 at 8:01 PM
    That Dude Tim
    Elyria, OH
    Yeah start up your truck and "torque" the motor. Left foot hard on brake pedal, shifter in D, and pulse the gas pedal with your right foot. Doing this usually causes enough movement/ vibration from the motor to help make exhaust pipe/ shield noise occur. Where I live usually the 10mm nuts will wear/ corrode through the shield and let it hang. Removing the nut and adding a larger washer is a easy/cheap fix.
  8. Oct 24, 2016 at 8:07 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    I had a rattle from 1600-1800 but went away after the truck warmed up (usually a few miles). Does your rattle ever go away or is it constantly there?
    I ended up changing the oil and spark plugs and then banged on the exhaust trying to find where the rattle could be coming from. After I was done with the oil change and spark plugs, it hasn't rattled since. I don't know if it was from old/low oil or what, but I would at least check your oil and see if its low.
  9. Oct 24, 2016 at 8:10 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the shield mounted to the cab floor above the cat
  10. Oct 24, 2016 at 8:13 PM
    needataco
    This is exactly what I did to fix the heat shield above the cats. Unfortunately the sound remains unchanged.
  11. Oct 24, 2016 at 8:14 PM
    needataco
    Cold or warmed up doesn't seem to have an effect on the noise.
  12. Oct 24, 2016 at 8:20 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I can't hear shit
    srsly it could be heat shield in the engine bay around
    exhaust manifold. bang on all that stuff when cold...
